CloudCompare 3D entities
Public Member Functions | Static Public Attributes | List of all members
ccCylinder Class Reference
Cylinder (primitive) More...
#include <ccCylinder.h>
Inheritance diagram for ccCylinder:
Inheritance graph
[legend]
Collaboration diagram for ccCylinder:
Collaboration graph
[legend]
 ccCylinder (PointCoordinateType radius, PointCoordinateType height, const ccGLMatrix *transMat=nullptr, QString name=QString("Cylinder"), unsigned precision=DEFAULT_DRAWING_PRECISION, unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 Default constructor. More...
 ccCylinder (QString name=QString("Cylinder"))
 Simplified constructor. More...
virtual CC_CLASS_ENUM getClassID () const override
 Returns class ID. More...
virtual QString getTypeName () const override
 Returns type name (sphere, cylinder, etc.) More...
virtual ccGenericPrimitiveclone () const override
 Clones primitive. More...
virtual void setBottomRadius (PointCoordinateType radius) override
 Sets bottom radius. More...
virtual void setTopRadius (PointCoordinateType radius) override
 Sets top radius. More...
- Public Member Functions inherited from ccCone
 ccCone (PointCoordinateType bottomRadius, PointCoordinateType topRadius, PointCoordinateType height, PointCoordinateType xOff=0, PointCoordinateType yOff=0, const ccGLMatrix *transMat=nullptr, QString name=QString("Cone"), unsigned precision=DEFAULT_DRAWING_PRECISION, unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 ccCone (QString name=QString("Cone"))
PointCoordinateType getHeight () const
 Returns height.
void setHeight (PointCoordinateType height)
 Sets height. More...
PointCoordinateType getBottomRadius () const
 Returns bottom radius.
PointCoordinateType getTopRadius () const
 Returns top radius.
virtual CCVector3 getBottomCenter () const
 Returns cone axis bottom end point after applying transformation.
virtual CCVector3 getTopCenter () const
 Returns cone axis top end point after applying transformation.
virtual CCVector3 getSmallCenter () const
 Returns cone axis end point associated with whichever radii is smaller.
virtual CCVector3 getLargeCenter () const
 Returns cone axis end point associated with whichever radii is larger.
virtual PointCoordinateType getSmallRadius () const
 Returns whichever cone radii is smaller.
virtual PointCoordinateType getLargeRadius () const
 Returns whichever cone radii is larger.
virtual bool isSnoutMode () const
 Returns true if the Cone was created in snout mode.
virtual bool hasDrawingPrecision () const override
 Whether drawing is dependent on 'precision' parameter. More...
- Public Member Functions inherited from ccGenericPrimitive
 ccGenericPrimitive (QString name=QString(), const ccGLMatrix *transMat=nullptr, unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
virtual QString getTypeName () const =0
virtual ccGenericPrimitiveclone () const =0
virtual void setColor (const ccColor::Rgb &col)
 Sets primitive color (shortcut) More...
const ccGenericPrimitiveoperator+= (const ccGenericPrimitive &prim)
 Add operator. More...
virtual bool setDrawingPrecision (unsigned steps)
 Sets drawing precision. More...
virtual unsigned getDrawingPrecision () const
 Returns drawing precision (or 0 if feature is not supported)
virtual ccGLMatrixgetTransformation ()
 Returns the transformation that is currently applied to the vertices.
virtual const ccGLMatrixgetTransformation () const
 Returns the transformation that is currently applied to the vertices (const version)
const ccGLMatrixgetGLTransformationHistory () const override
- Public Member Functions inherited from ccMesh
 ccMesh (ccGenericPointCloud *vertices, unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 Default ccMesh constructor. More...
 ccMesh (CCCoreLib::GenericIndexedMesh *giMesh, ccGenericPointCloud *giVertices)
 ccMesh constructor (from a CCCoreLib::GenericIndexedMesh) More...
 ~ccMesh () override
 Default destructor.
void setAssociatedCloud (ccGenericPointCloud *cloud)
 Sets the associated vertices cloud (warning)
ccMeshcloneMesh (ccGenericPointCloud *vertices=nullptr, ccMaterialSet *clonedMaterials=nullptr, NormsIndexesTableType *clonedNormsTable=nullptr, TextureCoordsContainer *cloneTexCoords=nullptr)
 Clones this entity. More...
bool merge (const ccMesh *mesh, bool createSubMesh)
 Merges another mesh into this one. More...
unsigned getUniqueIDForDisplay () const override
ccBBox getOwnBB (bool withGLFeatures=false) override
ccGenericPointCloudgetAssociatedCloud () const override
 Returns the vertices cloud. More...
void refreshBB () override
 Forces bounding-box update. More...
bool interpolateNormalsBC (unsigned triIndex, const CCVector3d &w, CCVector3 &N) override
 Interpolates normal(s) inside a given triangle. More...
bool interpolateColors (unsigned triIndex, const CCVector3 &P, ccColor::Rgb &C) override
 Interpolates RGB colors inside a given triangle. More...
bool interpolateColorsBC (unsigned triIndex, const CCVector3d &w, ccColor::Rgb &C) override
bool interpolateColors (unsigned triIndex, const CCVector3 &P, ccColor::Rgba &C) override
 Interpolates RGBA colors inside a given triangle. More...
bool interpolateColorsBC (unsigned triIndex, const CCVector3d &w, ccColor::Rgba &C) override
void computeInterpolationWeights (unsigned triIndex, const CCVector3 &P, CCVector3d &weights) const override
 Returns the (barycentric) interpolation weights for a given triangle. More...
bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, ccColor::Rgba &C, bool interpolateColorIfNoTexture) override
 Returns RGB color fom a given triangle material/texture. More...
bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, ccColor::Rgba &color, bool returnColorIfNoTexture) override
 Returns RGB color of a vertex fom a given triangle material/texture. More...
unsigned capacity () const override
 Returns max capacity. More...
void forEach (genericTriangleAction action) override
void placeIteratorAtBeginning () override
CCCoreLib::GenericTriangle * _getNextTriangle () override
CCCoreLib::GenericTriangle * _getTriangle (unsigned triangleIndex) override
CCCoreLib::VerticesIndexes * getNextTriangleVertIndexes () override
CCCoreLib::VerticesIndexes * getTriangleVertIndexes (unsigned triangleIndex) override
void getTriangleVertices (unsigned triangleIndex, CCVector3 &A, CCVector3 &B, CCVector3 &C) const override
unsigned size () const override
void getBoundingBox (CCVector3 &bbMin, CCVector3 &bbMax) override
bool normalsAvailable () const override
bool interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N) override
virtual const CCCoreLib::VerticesIndexes * getTriangleVertIndexes (unsigned triangleIndex) const
bool hasColors () const override
bool hasNormals () const override
bool hasScalarFields () const override
bool hasDisplayedScalarField () const override
bool normalsShown () const override
void toggleMaterials () override
void invertNormals ()
 Inverts normals (if any) More...
void shiftTriangleIndexes (unsigned shift)
 Shifts all triangles indexes. More...
void flipTriangles ()
 Flips the triangle. More...
void addTriangle (unsigned i1, unsigned i2, unsigned i3)
 Adds a triangle to the mesh. More...
bool reserve (size_t n)
 Reserves the memory to store the vertex indexes (3 per triangle) More...
bool resize (size_t n)
 Resizes the array of vertex indexes (3 per triangle) More...
void shrinkToFit ()
 Removes unused capacity.
bool hasTriNormals () const override
 Returns whether the mesh has per-triangle normals. More...
void getTriangleNormalIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const override
 Returns a triplet of normal indexes for a given triangle (if any) More...
bool getTriangleNormals (unsigned triangleIndex, CCVector3 &Na, CCVector3 &Nb, CCVector3 &Nc) const override
 Returns a given triangle normal. More...
NormsIndexesTableTypegetTriNormsTable () const override
 Returns per-triangle normals shared array. More...
void setTriNormsTable (NormsIndexesTableType *triNormsTable, bool autoReleaseOldTable=true)
 Sets per-triangle normals array (may be shared)
void clearTriNormals ()
 Removes per-triangle normals.
bool arePerTriangleNormalsEnabled () const
 Returns whether per triangle normals are enabled. More...
bool reservePerTriangleNormalIndexes ()
 Reserves memory to store per-triangle triplets of normal indexes. More...
void addTriangleNormalIndexes (int i1, int i2, int i3)
 Adds a triplet of normal indexes for next triangle. More...
void setTriangleNormalIndexes (unsigned triangleIndex, int i1, int i2, int i3)
 Sets a triplet of normal indexes for a given triangle. More...
void removePerTriangleNormalIndexes ()
 Removes any per-triangle triplets of normal indexes.
void invertPerTriangleNormals ()
 Invert per-triangle normals.
bool hasMaterials () const override
 Returns whether the mesh has materials/textures. More...
const ccMaterialSetgetMaterialSet () const override
 Returns associated material set. More...
int getTriangleMtlIndex (unsigned triangleIndex) const override
 Returns a given triangle material indexes. More...
bool convertMaterialsToVertexColors ()
 Converts materials to vertex colors. More...
bool hasPerTriangleMtlIndexes () const
 Returns whether this mesh as per-triangle material index.
bool reservePerTriangleMtlIndexes ()
 Reserves memory to store per-triangle material index. More...
void removePerTriangleMtlIndexes ()
 Removes any per-triangle material indexes.
void addTriangleMtlIndex (int mtlIndex)
 Adds triangle material index for next triangle. More...
void setTriangleMtlIndexesTable (triangleMaterialIndexesSet *matIndexesTable, bool autoReleaseOldTable=true)
 Sets per-triangle material indexes array.
const triangleMaterialIndexesSetgetTriangleMtlIndexesTable () const
 Returns the per-triangle material indexes array.
void setTriangleMtlIndex (unsigned triangleIndex, int mtlIndex)
 Sets triangle material indexes. More...
void setMaterialSet (ccMaterialSet *materialSet, bool autoReleaseOldMaterialSet=true)
 Sets associated material set (may be shared)
bool hasTextures () const override
 Returns whether textures are available for this mesh. More...
TextureCoordsContainergetTexCoordinatesTable () const override
 Returns per-triangle texture coordinates array. More...
void getTriangleTexCoordinates (unsigned triIndex, TexCoords2D *&tx1, TexCoords2D *&tx2, TexCoords2D *&tx3) const override
 Returns per-triangle texture coordinates (pointer to) More...
bool hasPerTriangleTexCoordIndexes () const override
 Returns whether this mesh as per-triangle triplets of tex coords indexes. More...
void getTriangleTexCoordinatesIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const override
 Returns the triplet of tex coords indexes for a given triangle. More...
void setTexCoordinatesTable (TextureCoordsContainer *texCoordsTable, bool autoReleaseOldTable=true)
 Sets per-triangle texture coordinates array (may be shared)
bool reservePerTriangleTexCoordIndexes ()
 Reserves memory to store per-triangle triplets of tex coords indexes. More...
void removePerTriangleTexCoordIndexes ()
 Remove per-triangle tex coords indexes.
void addTriangleTexCoordIndexes (int i1, int i2, int i3)
 Adds a triplet of tex coords indexes for next triangle. More...
void setTriangleTexCoordIndexes (unsigned triangleIndex, int i1, int i2, int i3)
 Sets a triplet of tex coords indexes for a given triangle. More...
bool computeNormals (bool perVertex)
 Computes normals. More...
bool computePerVertexNormals ()
 Computes per-vertex normals. More...
bool computePerTriangleNormals ()
 Computes per-triangle normals.
bool laplacianSmooth (unsigned nbIteration=100, PointCoordinateType factor=static_cast< PointCoordinateType >(0.01), ccProgressDialog *progressCb=nullptr)
 Laplacian smoothing. More...
bool processScalarField (MESH_SCALAR_FIELD_PROCESS process)
 Applies process to the mesh scalar field (the one associated to its vertices in fact) More...
ccMeshsubdivide (PointCoordinateType maxArea) const
 Subdivides mesh (so as to ensure that all triangles are falls below 'maxArea') More...
ccMeshcreateNewMeshFromSelection (bool removeSelectedFaces)
 Creates a new mesh with the selected vertices only. More...
void swapTriangles (unsigned index1, unsigned index2)
 Swaps two triangles. More...
void transformTriNormals (const ccGLMatrix &trans)
 Transforms the mesh per-triangle normals.
bool mergeDuplicatedVertices (unsigned char octreeLevel=DefaultMergeDuplicateVerticesLevel, QWidget *parentWidget=nullptr)
 Merges duplicated vertices.
- Public Member Functions inherited from ccGenericMesh
 ccGenericMesh (QString name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 ~ccGenericMesh () override=default
 Destructor.
void showNormals (bool state) override
virtual ccGenericPointCloudgetAssociatedCloud () const =0
virtual void refreshBB ()=0
virtual unsigned capacity () const =0
virtual bool hasMaterials () const =0
virtual const ccMaterialSetgetMaterialSet () const =0
virtual int getTriangleMtlIndex (unsigned triangleIndex) const =0
virtual bool hasTextures () const =0
virtual TextureCoordsContainergetTexCoordinatesTable () const =0
virtual void getTriangleTexCoordinates (unsigned triIndex, TexCoords2D *&tx1, TexCoords2D *&tx2, TexCoords2D *&tx3) const =0
virtual bool hasPerTriangleTexCoordIndexes () const =0
virtual void getTriangleTexCoordinatesIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const =0
virtual bool hasTriNormals () const =0
virtual void getTriangleNormalIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const =0
virtual bool getTriangleNormals (unsigned triangleIndex, CCVector3 &Na, CCVector3 &Nb, CCVector3 &Nc) const =0
virtual NormsIndexesTableTypegetTriNormsTable () const =0
virtual void computeInterpolationWeights (unsigned triIndex, const CCVector3 &P, CCVector3d &weights) const
virtual bool interpolateNormalsBC (unsigned triIndex, const CCVector3d &w, CCVector3 &N)=0
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, ccColor::Rgb &color)=0
virtual bool interpolateColorsBC (unsigned triIndex, const CCVector3d &w, ccColor::Rgb &color)=0
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, ccColor::Rgba &color)=0
virtual bool interpolateColorsBC (unsigned triIndex, const CCVector3d &w, ccColor::Rgba &color)=0
virtual bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, ccColor::Rgba &color, bool interpolateColorIfNoTexture)=0
virtual bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, ccColor::Rgba &color, bool returnColorIfNoTexture)=0
virtual bool isShownAsWire () const
 Returns whether the mesh is displayed as wired or with plain facets.
virtual void showWired (bool state)
 Sets whether mesh should be displayed as a wire or with plain facets.
virtual bool triNormsShown () const
 Returns whether per-triangle normals are shown or not.
virtual void showTriNorms (bool state)
 Sets whether to show or not per-triangle normals.
virtual bool materialsShown () const
 Sets whether textures/material should be displayed or not.
virtual void showMaterials (bool state)
 Sets whether textures should be displayed or not.
virtual bool stipplingEnabled () const
 Returns whether polygon stippling is enabled or not.
void enableStippling (bool state)
 Enables polygon stippling.
ccPointCloudsamplePoints (bool densityBased, double samplingParameter, bool withNormals, bool withRGB, bool withTexture, CCCoreLib::GenericProgressCallback *pDlg=nullptr)
 Samples points on a mesh.
void importParametersFrom (const ccGenericMesh *mesh)
 Imports the parameters from another mesh. More...
virtual bool trianglePicking (const CCVector2d &clickPos, const ccGLCameraParameters &camera, int &nearestTriIndex, double &nearestSquareDist, CCVector3d &nearestPoint, CCVector3d *barycentricCoords=nullptr) const
 Brute force triangle picking. More...
virtual bool trianglePicking (unsigned triIndex, const CCVector2d &clickPos, const ccGLCameraParameters &camera, CCVector3d &point, CCVector3d *barycentricCoords=nullptr) const
 Triangle picking (single triangle)
bool computePointPosition (unsigned triIndex, const CCVector2d &uv, CCVector3 &P, bool warningIfOutside=true) const
 Computes the point that corresponds to the given uv (barycentric) coordinates.
void setGlobalShift (const CCVector3d &shift) override
 Sets shift applied to original coordinates (information storage only) More...
void setGlobalScale (double scale) override
 Sets the scale applied to original coordinates (information storage only) More...
const CCVector3d & getGlobalShift () const override
 Returns the shift applied to original coordinates. More...
double getGlobalScale () const override
 Returns the scale applied to original coordinates. More...
- Public Member Functions inherited from ccShiftedObject
 ccShiftedObject (QString name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 ccShiftedObject (const ccShiftedObject &s)=default
 Copy constructor. More...
void copyGlobalShiftAndScale (const ccShiftedObject &s)
 Copies the Global Shift and Scale from another entity. More...
virtual void setGlobalShift (double x, double y, double z)
virtual void setGlobalShift (const CCVector3d &shift)
virtual const CCVector3d & getGlobalShift () const
virtual void setGlobalScale (double scale)
virtual double getGlobalScale () const
bool isShifted () const
 Returns whether the cloud is shifted or not.
template<typename T >
CCVector3d toGlobal3d (const Vector3Tpl< T > &Plocal) const
 Returns the point back-projected into the original coordinates system.
CCVector3d toLocal3d (const Vector3Tpl< T > &Pglobal) const
 Returns the point projected into the local (shifted) coordinates system.
CCVector3 toLocal3pc (const Vector3Tpl< T > &Pglobal) const
bool getOwnGlobalBB (CCVector3d &minCorner, CCVector3d &maxCorner) override
GlobalBoundingBox getOwnGlobalBB (bool withGLFeatures=false) override
 Copy constructor.
 ~ccHObject () override
 Default destructor.
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
static const unsigned DEFAULT_DRAWING_PRECISION = 24
 Default drawing precision. More...
- Static Public Attributes inherited from ccCone
- Static Public Attributes inherited from ccGenericPrimitive
static const int MIN_DRAWING_PRECISION = 4
 Minimum drawing precision. More...
- Static Public Attributes inherited from ccMesh
static const unsigned char DefaultMergeDuplicateVerticesLevel = 10
 Default octree level for the 'mergeDuplicatedVertices' algorithm.
Additional Inherited Members
- Public Types inherited from ccMesh
enum  MESH_SCALAR_FIELD_PROCESS { SMOOTH_MESH_SF , ENHANCE_MESH_SF }
 Mesh scalar field processes. More...
using triangleMaterialIndexesSet = ccArray< int, 1, int >
 Container of per-triangle material descriptors.
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
- Static Public Member Functions inherited from ccMesh
static ccMeshTriangulate (ccGenericPointCloud *cloud, CCCoreLib::TRIANGULATION_TYPES type, bool updateNormals=false, PointCoordinateType maxEdgeLength=0, unsigned char dim=2)
 Creates a Delaunay 2.5D mesh from a point cloud. More...
static ccMeshTriangulateTwoPolylines (ccPolyline *p1, ccPolyline *p2, CCVector3 *projectionDir=nullptr)
 Creates a Delaunay 2.5D mesh from two polylines.
- Static Public Member Functions inherited from ccGenericMesh
static bool IsCloudVerticesOfMesh (ccGenericPointCloud *cloud, ccGenericMesh **mesh=nullptr)
 Helper to determine if the input cloud acts as vertices of a mesh.
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
- Protected Types inherited from ccMesh
using triangleIndexesContainer = ccArray< CCCoreLib::VerticesIndexes, 3, unsigned >
 Container of per-triangle vertices indexes (3)
using triangleTexCoordIndexesSet = ccArray< Tuple3i, 3, int >
 Set of triplets of indexes referring to mesh texture coordinates.
using triangleNormalsIndexesSet = ccArray< Tuple3i, 3, int >
 Set of triplets of indexes referring to mesh normals.
- Protected Member Functions inherited from ccCone
virtual bool toFile_MeOnly (QFile &out) const override
 Save own object data. More...
virtual bool fromFile_MeOnly (QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) override
virtual bool buildUp () override
 Builds primitive. More...
- Protected Member Functions inherited from ccGenericPrimitive
void applyGLTransformation (const ccGLMatrix &trans) override
 Inherited from ccGenericMesh. More...
virtual bool buildUp ()=0
virtual bool updateRepresentation ()
 Updates internal representation (as a mesh) More...
bool init (unsigned vertCount, bool vertNormals, unsigned faceCount, unsigned faceNormCount)
 Inits internal structures. More...
void applyTransformationToVertices ()
 Applies associated transformation to vertices. More...
ccGenericPrimitivefinishCloneJob (ccGenericPrimitive *primitive) const
 Finished 'clone' job (vertices color, etc.) More...
ccPointCloudvertices ()
 Returns vertices.
- Protected Member Functions inherited from ccMesh
void onUpdateOf (ccHObject *obj) override
void onDeletionOf (const ccHObject *obj) override
void computeInterpolationWeights (const CCCoreLib::VerticesIndexes &vertIndexes, const CCVector3 &P, CCVector3d &weights) const
 Same as other 'computeInterpolationWeights' method with a set of 3 vertices indexes.
bool interpolateNormals (const CCCoreLib::VerticesIndexes &vertIndexes, const CCVector3d &w, CCVector3 &N, const Tuple3i *triNormIndexes=nullptr)
 Same as other 'interpolateNormals' method with a set of 3 vertices indexes.
bool interpolateColors (const CCCoreLib::VerticesIndexes &vertIndexes, const CCVector3d &w, ccColor::Rgb &C)
 Same as other 'interpolateColors' method with a set of 3 vertices indexes.
bool interpolateColors (const CCCoreLib::VerticesIndexes &vertIndexes, const CCVector3d &w, ccColor::Rgba &C)
bool pushSubdivide (unsigned indexA, unsigned indexB, unsigned indexC)
 Used internally by 'subdivide'.
- Protected Member Functions inherited from ccGenericMesh
virtual bool trianglePicking (unsigned triIndex, const CCVector2d &clickPos, const ccGLMatrix &trans, bool noGLTrans, const ccGenericPointCloud &vertices, const ccGLCameraParameters &camera, CCVector3d &point, CCVector3d *barycentricCoords=nullptr, QPainter *painter=nullptr) const
void handleColorRamp (CC_DRAW_CONTEXT &context)
 Handles the color ramp display.
- Protected Member Functions inherited from ccShiftedObject
bool saveShiftInfoToFile (QFile &out) const
 Serialization helper (output)
bool loadShiftInfoFromFile (QFile &in)
 Serialization helper (input)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
- Static Protected Member Functions inherited from ccGenericMesh
static CCVector3 * GetVertexBuffer ()
static CCVector3 * GetNormalsBuffer ()
static ColorCompType * GetColorsBuffer ()
static unsigned * GetWireVertexIndexes ()
 Returns a pre-initialized array of vertex indexes for wired display. More...
static void EnableGLStippleMask (const QOpenGLContext *context, bool state)
 Enables (OpenGL) stipple mask.
- Protected Attributes inherited from ccCone
PointCoordinateType m_bottomRadius
 Bottom radius.
PointCoordinateType m_topRadius
 Top radius.
PointCoordinateType m_xOff
 Displacement of axes along X-axis (Snout mode)
PointCoordinateType m_yOff
 Displacement of axes along Y-axis (Snout mode)
PointCoordinateType m_height
 Height.
- Protected Attributes inherited from ccGenericPrimitive
ccGLMatrix m_transformation
 Associated transformation (applied to vertices) More...
unsigned m_drawPrecision
 Drawing precision (for primitives that support this feature)
- Protected Attributes inherited from ccMesh
ccMesh_extended_call1(showNormals, bool, showNormals_extended) protected NormsIndexesTableTypem_triNormals
 Per-triangle normals.
TextureCoordsContainerm_texCoords
 Texture coordinates.
ccMaterialSetm_materials
 Materials.
triangleIndexesContainerm_triVertIndexes
 Triangles' vertices indexes (3 per triangle)
unsigned m_globalIterator
 Iterator on the list of triangles.
CCCoreLib::SimpleRefTriangle m_currentTriangle
 Dump triangle structure to transmit temporary data.
ccBBox m_bBox
 Bounding-box.
triangleMaterialIndexesSetm_triMtlIndexes
 Per-triangle material indexes.
triangleTexCoordIndexesSetm_texCoordIndexes
 Mesh tex coords indexes (per-triangle)
triangleNormalsIndexesSetm_triNormalIndexes
 Mesh normals indexes (per-triangle)
- Protected Attributes inherited from ccGenericMesh
bool m_triNormsShown
 Per-triangle normals display flag.
bool m_materialsShown
 Texture/material display flag.
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
- Protected Attributes inherited from ccShiftedObject
CCVector3d m_globalShift
 Global shift (typically applied at loading time)
double m_globalScale
 Global scale (typically applied at loading time)
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Detailed Description
3D cylinder primitive
◆ ccCylinder() [1/2]
ccCylinder::ccCylinder ( PointCoordinateType  radius,
const ccGLMatrix transMat = nullptr,
QString  name = QString("Cylinder"),
unsigned  precision = DEFAULT_DRAWING_PRECISION,
unsigned  uniqueID = ccUniqueIDGenerator::InvalidUniqueID
Cylinder axis corresponds to the 'Z' dimension. Internally represented by a cone with the same top and bottom radius.
Parameters
radiuscylinder radius
heightcylinder height (transformation should point to the axis center)
transMatoptional 3D transformation (can be set afterwards with ccDrawableObject::setGLTransformation)
namename
precisiondrawing precision (angular step = 360/precision)
uniqueIDunique ID (handle with care)
◆ ccCylinder() [2/2]
ccCylinder::ccCylinder ( QString  name = QString("Cylinder"))
For ccHObject factory only!
Member Function Documentation
◆ clone()
ccGenericPrimitive * ccCylinder::clone ( ) const
overridevirtual
Clones primitive.
Reimplemented from ccCone.
◆ getClassID()
virtual CC_CLASS_ENUM ccCylinder::getClassID ( ) const
inlineoverridevirtual
Returns class ID.
◆ getTypeName()
virtual QString ccCylinder::getTypeName ( ) const
◆ setBottomRadius()
void ccCylinder::setBottomRadius ( PointCoordinateType  radius)
overridevirtual
Sets bottom radius.
Warning
changes primitive content (calls ccGenericPrimitive::updateRepresentation)
◆ setTopRadius()
virtual void ccCylinder::setTopRadius ( PointCoordinateType  radius)
Sets top radius.
Warning
Member Data Documentation
◆ DEFAULT_DRAWING_PRECISION
const unsigned ccCylinder::DEFAULT_DRAWING_PRECISION = 24
static
Warning
Never pass a 'constant initializer' by reference
