CloudCompare 3D entities
Public Types | Public Member Functions | Static Public Member Functions | Public Attributes | Protected Member Functions | Protected Attributes | List of all members
ccHObject Class Reference
Hierarchical CloudCompare Object. More...
#include <ccHObject.h>
Inheritance diagram for ccHObject:
Inheritance graph
[legend]
Collaboration diagram for ccHObject:
Collaboration graph
[legend]
Public Types
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
 Default constructor. More...
 Copy constructor.
 ~ccHObject () override
 Default destructor.
 Returns class ID. More...
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Public Attributes
 Sets parent object.
 Save own object data. More...
 Returns flag state.
 Sets flag state. More...
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Detailed Description
Member Enumeration Documentation
◆ DEPENDENCY_FLAGS
Dependency flags.
Enumerator
DP_NONE
no dependency
DP_NOTIFY_OTHER_ON_DELETE
notify 'other' when deleted (will call ccHObject::onDeletionOf)
DP_NOTIFY_OTHER_ON_UPDATE
notify 'other' when its geometry is modified (will call ccHObject::onUpdateOf)
DP_DELETE_OTHER
delete 'other' before deleting itself
DP_PARENT_OF_OTHER
same as DP_DELETE_OTHER + declares itself as parent of 'other'
◆ ccHObject()
ccHObject::ccHObject ( const QString &  name = QString(),
unsigned  uniqueID = ccUniqueIDGenerator::InvalidUniqueID
Parameters
nameobject name (optional)
uniqueIDunique ID (handle with care)
Member Function Documentation
◆ addChild()
bool ccHObject::addChild ( ccHObject child,
int  dependencyFlags = DP_PARENT_OF_OTHER,
int  insertIndex = -1
virtual
Adds a child.
Warning
by default (i.e. with the DP_PARENT_OF_OTHER flag) the child's parent will be automatically replaced by this instance. Moreover the child will be deleted
Parameters
childchild instance
dependencyFlagsdependency flags
insertIndexinsertion index (if <0, child is simply appended to the children list)
Returns
success
◆ addDependency()
void ccHObject::addDependency ( ccHObject otherObject,
int  flags,
bool  additive = true
Adds a new dependence (additive or not)
Parameters
otherObjectother object
flagsdependency flags (see DEPENDENCY_FLAGS)
additivewhether we should 'add' the flag(s) if there's already a dependence with the other object or not
◆ applyGLTransformation()
void ccHObject::applyGLTransformation ( const ccGLMatrix trans)
protectedvirtual
Applies a GL transformation to the entity.
this = rotMat*(this-rotCenter)+(rotCenter+trans)
Parameters
transa ccGLMatrix structure
Reimplemented in ccFacet, ccGenericPrimitive, ccMesh, ccPolyline, and ccSensor.
◆ applyGLTransformation_recursive()
void ccHObject::applyGLTransformation_recursive ( const ccGLMatrix trans = nullptr)
Applies the active OpenGL transformation to the entity (recursive)
The input ccGLMatrix should be left to 0, unless you want to apply a pre-transformation.
Parameters
transa ccGLMatrix structure (reference to)
◆ detachAllChildren()
void ccHObject::detachAllChildren ( )
Removes a specific child.
Warning
This method may delete the child if the DP_PARENT_OF_OTHER dependency flag is set for this child (use detachChild if you want to avoid deletion). Detaches all children
◆ detachChild()
void ccHObject::detachChild ( ccHObject child)
Detaches a specific child.
This method does not delete the child. Removes any dependency between the flag and this object
◆ draw()
void ccHObject::draw ( CC_DRAW_CONTEXT context)
overridevirtual
Draws entity and its children.
Implements ccDrawableObject.
◆ drawBB()
void ccHObject::drawBB ( CC_DRAW_CONTEXT context,
const ccColor::Rgb col
virtual
Draws the entity (and its children) bounding-box.
Reimplemented in ccPolyline.
◆ drawMeOnly()
virtual void ccHObject::drawMeOnly ( CC_DRAW_CONTEXT context)
inlineprotectedvirtual
◆ drawNameIn3D()
void ccHObject::drawNameIn3D ( CC_DRAW_CONTEXT context)
protectedvirtual
Draws the entity name in 3D.
Names is displayed at the center of the bounding box by default.
Reimplemented in ccSphere.
◆ filterChildren()
unsigned ccHObject::filterChildren ( Container filteredChildren,
bool  recursive = false,
CC_CLASS_ENUM  filter = CC_TYPES::OBJECT,
bool  strict = false,
ccGenericGLDisplay inDisplay = nullptr
) const
Collects the children corresponding to a certain pattern.
Parameters
filteredChildrenresult container
recursivespecifies if the search should be recursive
filterpattern for children selection
strictwhether the search is strict on the type (i.e 'isA') or not (i.e. 'isKindOf')
inDisplay[optional] display in which the children are displayed
Returns
number of collected children
◆ find()
ccHObject * ccHObject::find ( unsigned  uniqueID) const
Finds an entity in this object hierarchy.
Parameters
uniqueIDchild unique ID
Returns
child (or nullptr if not found)
◆ fromFile()
bool ccHObject::fromFile ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
overridevirtual
Loads data from binary stream.
Parameters
ininput file (already opened)
dataVersionfile version
Returns
success
Reimplemented from ccSerializableObject.
◆ fromFile_MeOnly()
bool ccHObject::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags,
protectedvirtual
◆ fromFileNoChildren()
bool ccHObject::fromFileNoChildren ( QFile &  in,
short  dataVersion,
int  flags,
Custom version of ccSerializableObject::fromFile.
This is used to load only the object's part of a stream (and not its children)
Parameters
oldToNewIDMapmap to convert old IDs to new ones
Returns
success
◆ getAbsoluteGLTransformation()
bool ccHObject::getAbsoluteGLTransformation ( ccGLMatrix trans) const
Returns the absolute transformation (i.e. the actual displayed GL transformation) of an entity.
Parameters
[out]transabsolute transformation
Returns
whether a GL transformation is actually enabled or not
◆ getBB_recursive()
ccBBox ccHObject::getBB_recursive ( bool  withGLFeatures = false,
bool  onlyEnabledChildren = true
virtual
Returns the local bounding-box of this entity and it's children.
Parameters
withGLFeatureswhether to take into account display-only elements (if any)
onlyEnabledChildrenonly consider the 'enabled' children
Returns
bounding-box
◆ getChild()
ccHObject * ccHObject::getChild ( unsigned  childPos) const
inline
Returns the ith child.
Parameters
childPoschild position
Returns
child object (or nullptr if wrong position)
◆ getChildCountRecursive()
unsigned int ccHObject::getChildCountRecursive ( ) const
Returns the total number of children under this object recursively.
Returns
Number of children
◆ getChildrenNumber()
unsigned ccHObject::getChildrenNumber ( ) const
inline
Returns the number of children.
Returns
children number
◆ getClassID()
CC_CLASS_ENUM ccHObject::getClassID ( ) const
inlineoverridevirtual
◆ getDependencyFlagsWith()
int ccHObject::getDependencyFlagsWith ( const ccHObject otherObject) const
Returns the dependency flags with a given object.
Parameters
◆ getDisplayBB_recursive()
ccBBox ccHObject::getDisplayBB_recursive ( bool  relative,
const ccGenericGLDisplay display = nullptr
virtual
Returns the bounding-box of this entity and it's children WHEN DISPLAYED.
Children's GL transformation is taken into account (if enabled).
Parameters
relativewhether the bounding-box is relative (i.e. in the entity's local coordinate system) or absolute (in which case the parent's GL transformation will be taken into account)
displayif not null, this method will return the bounding-box of this entity (and its children) in the specified 3D view (i.e. potentially not visible)
Returns
bounding-box
◆ getGlobalBB_recursive()
ccHObject::GlobalBoundingBox ccHObject::getGlobalBB_recursive ( bool  withGLFeatures = false,
virtual
Returns the global bounding-box of this entity and it's children.
Parameters
Returns
bounding-box
◆ getGLTransformationHistory()
virtual const ccGLMatrix & ccHObject::getGLTransformationHistory ( ) const
inlinevirtual
Returns the transformation 'history' matrix.
Reimplemented in ccGenericPrimitive, and ccMesh.
◆ getIcon()
QIcon ccHObject::getIcon ( ) const
virtual
Returns the icon associated to this entity.
ccDBRoot will call this method: if an invalid icon is returned the default icon for that type will be used instead.
Returns
invalid icon by default (to be re-implemented by child class)
◆ getOwnBB()
ccBBox ccHObject::getOwnBB ( bool  withGLFeatures = false)
virtual
Returns the entity's own bounding-box (with local/shifted coordinates)
Children bounding-boxes are ignored.
Parameters
Returns
bounding-box
Reimplemented in ccCameraSensor, ccClipBox, ccGBLSensor, ccGenericPointCloud, ccIndexedTransformationBuffer, ccKdTree, ccMesh, ccOctreeProxy, ccPolyline, and ccSubMesh.
◆ getOwnFitBB()
virtual ccBBox ccHObject::getOwnFitBB ( ccGLMatrix trans)
inlinevirtual
Returns best-fit bounding-box (if available)
Warning
Only suitable for leaf objects (i.e. without children) Therefore children bboxes are always ignored.
This method is not supported by all entities! (returns the axis-aligned bounding-box by default).
Parameters
[out]transassociated transformation (so that the bounding-box can be displayed in the right position!)
Returns
fit bounding-box
Reimplemented in ccCameraSensor, ccGBLSensor, ccImage, ccPlane, and ccQuadric.
◆ getOwnGlobalBB() [1/2]
ccHObject::GlobalBoundingBox ccHObject::getOwnGlobalBB ( bool  withGLFeatures = false)
virtual
Returns the entity's own global bounding-box (with global/non-shifted coordinates - if relevant)
Children bounding-boxes are ignored. May differ from the (local) bounding-box if the entity is shifted
Parameters
Returns
global bounding-box
Reimplemented in ccShiftedObject.
◆ getOwnGlobalBB() [2/2]
bool ccHObject::getOwnGlobalBB ( CCVector3d &  minCorner,
CCVector3d &  maxCorner
virtual
Children bounding-boxes are ignored. By default this method returns the local bounding-box! But it may differ from the (local) bounding-box if the entity is shifted.
Parameters
[out]minCornermin global bounding-box corner
[out]maxCornermax global bounding-box corner
Returns
whether the bounding box is valid or not
◆ getParent()
ccHObject * ccHObject::getParent ( ) const
inline
Returns parent object.
Returns
parent object (nullptr if no parent)
◆ getUniqueIDForDisplay()
virtual unsigned ccHObject::getUniqueIDForDisplay ( ) const
inlinevirtual
Returns object unique ID used for display.
Reimplemented in ccMesh, and ccPolyline.
◆ isSerializable()
bool ccHObject::isSerializable ( ) const
overridevirtual
◆ isShareable()
virtual bool ccHObject::isShareable ( ) const
inlinevirtual
◆ New() [1/2]
ccHObject * ccHObject::New ( CC_CLASS_ENUM  objectType,
const char *  name = nullptr
static
Static factory.
Warning
Objects depending on other structures (such as meshes or polylines that should be linked with point clouds playing the role of vertices) are returned 'naked'.
Parameters
objectTypeobject type
Returns
instantiated object (if type is valid) or 0
◆ New() [2/2]
ccHObject * ccHObject::New ( const QString &  pluginId,
const QString &  classId,
static
Static factory (version to be used by external plugin factories)
Two strings are used as keys, one for the plugin name and one for the class name. Those strings will typically be saved as metadata of a custom object
◆ onDeletionOf()
void ccHObject::onDeletionOf ( const ccHObject obj)
protectedvirtual
This method is called when another object is deleted.
For internal use.
Reimplemented in cc2DLabel, ccImage, and ccMesh.
◆ onUpdateOf()
virtual void ccHObject::onUpdateOf ( ccHObject obj)
This method is called when another object (geometry) is updated.
For internal use.
Reimplemented in ccMesh, and ccSubMesh.
◆ popDisplayState()
void ccHObject::popDisplayState ( bool  apply = true)
overridevirtual
Pops the last pushed display state (overridden)
Reimplemented from ccDrawableObject.
◆ pushDisplayState()
bool ccHObject::pushDisplayState ( )
overridevirtual
Pushes the current display state (overridden)
◆ removeChild()
void ccHObject::removeChild ( int  pos)
Removes a specific child given its index.
Warning
◆ removeDependencyFlag()
void ccHObject::removeDependencyFlag ( ccHObject otherObject,
DEPENDENCY_FLAGS  flag
Removes a given dependency flag.
Parameters
flagdependency flag to remove (see DEPENDENCY_FLAGS)
◆ removeDependencyWith()
void ccHObject::removeDependencyWith ( ccHObject otherObject)
Removes any dependency flags with a given object.
Parameters
◆ setSelectionBehavior()
virtual void ccHObject::setSelectionBehavior ( SelectionBehavior  mode)
inlinevirtual
Sets selection behavior (when displayed)
Warning
SELECTION_FIT_BBOX relies on the 'ccDrawableObject::getFitBB' method (which is not supported by all entities).
◆ toFile()
bool ccHObject::toFile ( QFile &  out) const
overridevirtual
Saves data to binary stream.
Parameters
outoutput file (already opened)
Returns
success
◆ toFile_MeOnly()
bool ccHObject::toFile_MeOnly ( QFile &  out) const
protectedvirtual
Member Data Documentation
◆ m_dependencies
std::map<ccHObject*, int> ccHObject::m_dependencies
protected
Dependencies map.
First parameter: other object Second parameter: dependency flags (see DEPENDENCY_FLAGS)
◆ m_glTransHistory
ccGLMatrix ccHObject::m_glTransHistory
protected
Cumulative GL transformation.
History of all the applied transformations since the creation of the object as a single transformation.
◆ newDisplay
ccGenericGLDisplay setDisplay_recursive prepareDisplayForRefresh_recursive resetGLTransformationHistory_recursive toggleVisibility_recursive toggleNormals_recursive toggleShowName_recursive ccGenericGLDisplay* ccHObject::newDisplay
Initial value:
if (getDisplay() == oldDisplay)
setDisplay(newDisplay);
for (auto child : m_children)
child->transferDisplay(oldDisplay, newDisplay);
unsigned findMaxUniqueID_recursive() const
virtual ccGenericGLDisplay * getDisplay() const
Definition: ccDrawableObject.h:169
virtual void setDisplay(ccGenericGLDisplay *win)
Definition: ccDrawableObject.cpp:73
Children.
Definition: ccHObject.h:465
