CloudCompare 3D entities
Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccIndexedTransformationBuffer Class Reference
Indexed Transformation buffer. More...
#include <ccIndexedTransformationBuffer.h>
Inheritance diagram for ccIndexedTransformationBuffer:
Inheritance graph
[legend]
Collaboration diagram for ccIndexedTransformationBuffer:
Collaboration graph
[legend]
 ccIndexedTransformationBuffer (const QString &name=QString("Trans. buffer"))
 Default constructor.
 ccIndexedTransformationBuffer (const ccIndexedTransformationBuffer &buffer)
 Copy constructor.
 Returns class ID. More...
void sort ()
 Sorts transformations based on their index. More...
bool findNearest (double index, const ccIndexedTransformation *&trans1, const ccIndexedTransformation *&trans2, size_t *trans1IndexInBuffer=nullptr, size_t *trans2IndexInBuffer=nullptr) const
 Returns the nearest indexed transformation(s) to a given index. More...
bool getInterpolatedTransformation (double index, ccIndexedTransformation &trans, double maxIndexDistForInterpolation=DBL_MAX) const
 Returns the indexed transformation at a given index (interpolates it if necessary) More...
bool trihedronsShown () const
 [Display option] Returns whether trihedrons should be displayed or not (otherwise only points or a polyline)
void showTrihedrons (bool state)
 [Display option] Sets whether trihedrons should be displayed or not (otherwise only points or a polyline)
float trihedronsDisplayScale () const
 [Display option] Returns trihedron display size
void setTrihedronsDisplayScale (float scale)
 [Display option] Sets trihedron display size
bool isPathShownAsPolyline () const
 [Display option] Returns whether the path should be displayed as a polyline or not (otherwise only points)
void showPathAsPolyline (bool state)
 [Display option] Sets whether the path should be displayed as a polyline or not (otherwise only points)
void invalidateBoundingBox ()
 Invalidates the bounding box. More...
ccBBox getOwnBB (bool withGLFeatures=false) override
 Default constructor. More...
 Copy constructor.
 ~ccHObject () override
 Default destructor.
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
 Save own object data. More...
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
ccBBox m_bBox
 Bounding box.
size_t m_bBoxValidSize
 Bounding box last 'validity' size.
bool m_showAsPolyline
 Whether the path should be displayed as a polyline or not.
bool m_showTrihedrons
 Whether trihedrons should be displayed or not.
float m_trihedronsScale
 Trihedrons display scale.
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Detailed Description
Member Function Documentation
◆ drawMeOnly()
void ccIndexedTransformationBuffer::drawMeOnly ( CC_DRAW_CONTEXT context)
overrideprotectedvirtual
Draws the entity only (not its children)
Reimplemented from ccHObject.
◆ findNearest()
bool ccIndexedTransformationBuffer::findNearest ( double  index,
const ccIndexedTransformation *&  trans1,
const ccIndexedTransformation *&  trans2,
size_t *  trans1IndexInBuffer = nullptr,
size_t *  trans2IndexInBuffer = nullptr
) const
This method returns the preceding and following transformations.
\warning Binary search: buffer must be sorted! (see ccIndexedTransformationBuffer::sort)
\param index query index (e.g. timestamp)
\param trans1 directly preceding transformation (if any - null otherwise)
\param trans2 directly following transformation (if any - null otherwise)
\param trans1IndexInBuffer (optional) index of trans1 in buffer
\param trans2IndexInBuffer (optional) index of trans2 in buffer
\return success
◆ fromFile_MeOnly()
bool ccIndexedTransformationBuffer::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
Loads own object data.
Called by 'fromFile' (recursive scheme) To be overloaded (but still called;) by subclass.
Parameters
ininput file
dataVersionfile version
◆ getClassID()
CC_CLASS_ENUM ccIndexedTransformationBuffer::getClassID ( ) const
inlineoverridevirtual
Returns class ID.
Returns
class unique ID
◆ getInterpolatedTransformation()
bool ccIndexedTransformationBuffer::getInterpolatedTransformation ( double  index,
ccIndexedTransformation trans,
double  maxIndexDistForInterpolation = DBL_MAX
) const
Warning
\param trans output transformation (if successful)
\param maxIndexDistForInterpolation max 'distance' between query index and existing indexes to actually interpolate/output a transformation
\return success
◆ getOwnBB()
ccBBox ccIndexedTransformationBuffer::getOwnBB ( bool  withGLFeatures = false)
overridevirtual
Returns the entity's own bounding-box (with local/shifted coordinates)
Children bounding-boxes are ignored.
Parameters
withGLFeatureswhether to take into account display-only elements (if any)
Returns
bounding-box
◆ invalidateBoundingBox()
void ccIndexedTransformationBuffer::invalidateBoundingBox ( )
Should be called whenever the content of this structure changes!
◆ isSerializable()
bool ccIndexedTransformationBuffer::isSerializable ( ) const
Returns whether object is serializable of not.
◆ sort()
void ccIndexedTransformationBuffer::sort ( )
Ascending sort.
◆ toFile_MeOnly()
bool ccIndexedTransformationBuffer::toFile_MeOnly ( QFile &  out) const
Called by 'toFile' (recursive scheme) To be overloaded (but still called;) by subclass.
