CloudCompare 3D entities
Public Types | Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
ccSubMesh Class Reference
A sub-mesh. More...
#include <ccSubMesh.h>
Inheritance diagram for ccSubMesh:
Inheritance graph
[legend]
Collaboration diagram for ccSubMesh:
Collaboration graph
[legend]
Public Types
using IndexMap = std::vector< unsigned int >
 Indexes map for createNewSubMeshFromSelection.
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
 ccSubMesh (ccMesh *parentMesh)
 Default constructor.
 ~ccSubMesh () override=default
 Destructor.
 Returns class ID. More...
ccBBox getOwnBB (bool withGLFeatures=false) override
ccGenericPointCloudgetAssociatedCloud () const override
 Returns the vertices cloud. More...
void refreshBB () override
 Forces bounding-box update. More...
bool interpolateNormalsBC (unsigned triIndex, const CCVector3d &w, CCVector3 &N) override
 Interpolates normal(s) inside a given triangle. More...
bool interpolateColors (unsigned triIndex, const CCVector3 &P, ccColor::Rgb &color) override
 Interpolates RGB colors inside a given triangle. More...
bool interpolateColorsBC (unsigned triIndex, const CCVector3d &w, ccColor::Rgb &color) override
bool interpolateColors (unsigned triIndex, const CCVector3 &P, ccColor::Rgba &color) override
 Interpolates RGBA colors inside a given triangle. More...
bool interpolateColorsBC (unsigned triIndex, const CCVector3d &w, ccColor::Rgba &color) override
bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, ccColor::Rgba &color, bool interpolateColorIfNoTexture) override
 Returns RGB color fom a given triangle material/texture. More...
bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, ccColor::Rgba &color, bool returnColorIfNoTexture) override
 Returns RGB color of a vertex fom a given triangle material/texture. More...
bool hasMaterials () const override
 Returns whether the mesh has materials/textures. More...
const ccMaterialSetgetMaterialSet () const override
 Returns associated material set. More...
int getTriangleMtlIndex (unsigned triangleIndex) const override
 Returns a given triangle material indexes. More...
bool hasTextures () const override
 Returns whether textures are available for this mesh. More...
TextureCoordsContainergetTexCoordinatesTable () const override
 Returns per-triangle texture coordinates array. More...
void getTriangleTexCoordinates (unsigned triIndex, TexCoords2D *&tx1, TexCoords2D *&tx2, TexCoords2D *&tx3) const override
 Returns per-triangle texture coordinates (pointer to) More...
bool hasPerTriangleTexCoordIndexes () const override
 Returns whether this mesh as per-triangle triplets of tex coords indexes. More...
void getTriangleTexCoordinatesIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const override
 Returns the triplet of tex coords indexes for a given triangle. More...
bool hasTriNormals () const override
 Returns whether the mesh has per-triangle normals. More...
void getTriangleNormalIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const override
 Returns a triplet of normal indexes for a given triangle (if any) More...
bool getTriangleNormals (unsigned triangleIndex, CCVector3 &Na, CCVector3 &Nb, CCVector3 &Nc) const override
 Returns a given triangle normal. More...
NormsIndexesTableTypegetTriNormsTable () const override
 Returns per-triangle normals shared array. More...
unsigned capacity () const override
 Returns max capacity. More...
void setGlobalShift (const CCVector3d &shift) override
 Sets shift applied to original coordinates (information storage only) More...
void setGlobalScale (double scale) override
 Sets the scale applied to original coordinates (information storage only) More...
bool hasColors () const override
bool hasNormals () const override
bool hasScalarFields () const override
bool hasDisplayedScalarField () const override
bool normalsShown () const override
unsigned size () const override
void forEach (genericTriangleAction action) override
void placeIteratorAtBeginning () override
CCCoreLib::GenericTriangle * _getNextTriangle () override
CCCoreLib::GenericTriangle * _getTriangle (unsigned index) override
CCCoreLib::VerticesIndexes * getNextTriangleVertIndexes () override
CCCoreLib::VerticesIndexes * getTriangleVertIndexes (unsigned triangleIndex) override
void getTriangleVertices (unsigned triangleIndex, CCVector3 &A, CCVector3 &B, CCVector3 &C) const override
void getBoundingBox (CCVector3 &bbMin, CCVector3 &bbMax) override
bool interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N) override
unsigned getTriGlobalIndex (unsigned localIndex) const
 Returns global index (i.e. relative to the associated mesh) of a given element. More...
unsigned getCurrentTriGlobalIndex () const
 Returns the global index of the triangle pointed by the current element.
void forwardIterator ()
 Forwards the local element iterator.
void clear (bool releaseMemory)
 Clears the mesh.
bool addTriangleIndex (unsigned globalIndex)
 Triangle global index insertion mechanism. More...
bool addTriangleIndex (unsigned firstIndex, unsigned lastIndex)
 Triangle global index insertion mechanism (range) More...
void setTriangleIndex (unsigned localIndex, unsigned globalIndex)
 Sets global index for a given element. More...
bool reserve (size_t n)
 Reserves some memory for hosting the triangle references. More...
bool resize (size_t n)
 Presets the size of the vector used to store triangle references. More...
ccMeshgetAssociatedMesh ()
 Returns the associated mesh.
const ccMeshgetAssociatedMesh () const
 Returns the associated mesh (const version)
void setAssociatedMesh (ccMesh *mesh, bool unlinkPreviousOne=true)
 Sets the associated mesh. More...
ccSubMeshcreateNewSubMeshFromSelection (bool removeSelectedFaces, IndexMap *indexMap=nullptr)
 Creates a new sub mesh with the selected vertices only. More...
- Public Member Functions inherited from ccGenericMesh
 ccGenericMesh (QString name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 Default constructor. More...
 ~ccGenericMesh () override=default
 Destructor.
void showNormals (bool state) override
virtual ccGenericPointCloudgetAssociatedCloud () const =0
virtual void refreshBB ()=0
virtual unsigned capacity () const =0
virtual bool hasMaterials () const =0
virtual const ccMaterialSetgetMaterialSet () const =0
virtual int getTriangleMtlIndex (unsigned triangleIndex) const =0
virtual bool hasTextures () const =0
virtual TextureCoordsContainergetTexCoordinatesTable () const =0
virtual void getTriangleTexCoordinates (unsigned triIndex, TexCoords2D *&tx1, TexCoords2D *&tx2, TexCoords2D *&tx3) const =0
virtual bool hasPerTriangleTexCoordIndexes () const =0
virtual void getTriangleTexCoordinatesIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const =0
virtual bool hasTriNormals () const =0
virtual void getTriangleNormalIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const =0
virtual bool getTriangleNormals (unsigned triangleIndex, CCVector3 &Na, CCVector3 &Nb, CCVector3 &Nc) const =0
virtual NormsIndexesTableTypegetTriNormsTable () const =0
virtual void computeInterpolationWeights (unsigned triIndex, const CCVector3 &P, CCVector3d &weights) const
 Returns the (barycentric) interpolation weights for a given triangle. More...
virtual bool interpolateNormalsBC (unsigned triIndex, const CCVector3d &w, CCVector3 &N)=0
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, ccColor::Rgb &color)=0
virtual bool interpolateColorsBC (unsigned triIndex, const CCVector3d &w, ccColor::Rgb &color)=0
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, ccColor::Rgba &color)=0
virtual bool interpolateColorsBC (unsigned triIndex, const CCVector3d &w, ccColor::Rgba &color)=0
virtual bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, ccColor::Rgba &color, bool interpolateColorIfNoTexture)=0
virtual bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, ccColor::Rgba &color, bool returnColorIfNoTexture)=0
virtual bool isShownAsWire () const
 Returns whether the mesh is displayed as wired or with plain facets.
virtual void showWired (bool state)
 Sets whether mesh should be displayed as a wire or with plain facets.
virtual bool triNormsShown () const
 Returns whether per-triangle normals are shown or not.
virtual void showTriNorms (bool state)
 Sets whether to show or not per-triangle normals.
virtual bool materialsShown () const
 Sets whether textures/material should be displayed or not.
virtual void showMaterials (bool state)
 Sets whether textures should be displayed or not.
virtual bool stipplingEnabled () const
 Returns whether polygon stippling is enabled or not.
void enableStippling (bool state)
 Enables polygon stippling.
ccPointCloudsamplePoints (bool densityBased, double samplingParameter, bool withNormals, bool withRGB, bool withTexture, CCCoreLib::GenericProgressCallback *pDlg=nullptr)
 Samples points on a mesh.
void importParametersFrom (const ccGenericMesh *mesh)
 Imports the parameters from another mesh. More...
virtual bool trianglePicking (const CCVector2d &clickPos, const ccGLCameraParameters &camera, int &nearestTriIndex, double &nearestSquareDist, CCVector3d &nearestPoint, CCVector3d *barycentricCoords=nullptr) const
 Brute force triangle picking. More...
virtual bool trianglePicking (unsigned triIndex, const CCVector2d &clickPos, const ccGLCameraParameters &camera, CCVector3d &point, CCVector3d *barycentricCoords=nullptr) const
 Triangle picking (single triangle)
bool computePointPosition (unsigned triIndex, const CCVector2d &uv, CCVector3 &P, bool warningIfOutside=true) const
 Computes the point that corresponds to the given uv (barycentric) coordinates.
const CCVector3d & getGlobalShift () const override
 Returns the shift applied to original coordinates. More...
double getGlobalScale () const override
 Returns the scale applied to original coordinates. More...
bool normalsAvailable () const override
- Public Member Functions inherited from ccShiftedObject
 ccShiftedObject (QString name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 ccShiftedObject (const ccShiftedObject &s)=default
 Copy constructor. More...
void copyGlobalShiftAndScale (const ccShiftedObject &s)
 Copies the Global Shift and Scale from another entity. More...
virtual void setGlobalShift (double x, double y, double z)
virtual void setGlobalShift (const CCVector3d &shift)
virtual const CCVector3d & getGlobalShift () const
virtual void setGlobalScale (double scale)
virtual double getGlobalScale () const
bool isShifted () const
 Returns whether the cloud is shifted or not.
template<typename T >
CCVector3d toGlobal3d (const Vector3Tpl< T > &Plocal) const
 Returns the point back-projected into the original coordinates system.
CCVector3d toLocal3d (const Vector3Tpl< T > &Pglobal) const
 Returns the point projected into the local (shifted) coordinates system.
CCVector3 toLocal3pc (const Vector3Tpl< T > &Pglobal) const
bool getOwnGlobalBB (CCVector3d &minCorner, CCVector3d &maxCorner) override
GlobalBoundingBox getOwnGlobalBB (bool withGLFeatures=false) override
 Copy constructor.
 ~ccHObject () override
 Default destructor.
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
Protected Types
using ReferencesContainer = std::vector< unsigned int >
 Container of 3D triangles indexes.
 Save own object data. More...
void onUpdateOf (ccHObject *obj) override
- Protected Member Functions inherited from ccGenericMesh
virtual bool trianglePicking (unsigned triIndex, const CCVector2d &clickPos, const ccGLMatrix &trans, bool noGLTrans, const ccGenericPointCloud &vertices, const ccGLCameraParameters &camera, CCVector3d &point, CCVector3d *barycentricCoords=nullptr, QPainter *painter=nullptr) const
void handleColorRamp (CC_DRAW_CONTEXT &context)
 Handles the color ramp display.
- Protected Member Functions inherited from ccShiftedObject
bool saveShiftInfoToFile (QFile &out) const
 Serialization helper (output)
bool loadShiftInfoFromFile (QFile &in)
 Serialization helper (input)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
ccMeshm_associatedMesh
 Associated mesh.
ReferencesContainer m_triIndexes
 Indexes of (some of) the associated mesh triangles.
unsigned m_globalIterator
 Iterator on the triangles references container.
ccBBox m_bBox
 Bounding-box.
- Protected Attributes inherited from ccGenericMesh
bool m_triNormsShown
 Per-triangle normals display flag.
bool m_materialsShown
 Texture/material display flag.
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
- Protected Attributes inherited from ccShiftedObject
CCVector3d m_globalShift
 Global shift (typically applied at loading time)
double m_globalScale
 Global scale (typically applied at loading time)
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Additional Inherited Members
- Static Public Member Functions inherited from ccGenericMesh
static bool IsCloudVerticesOfMesh (ccGenericPointCloud *cloud, ccGenericMesh **mesh=nullptr)
 Helper to determine if the input cloud acts as vertices of a mesh.
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
- Static Protected Member Functions inherited from ccGenericMesh
static CCVector3 * GetVertexBuffer ()
static CCVector3 * GetNormalsBuffer ()
static ColorCompType * GetColorsBuffer ()
static unsigned * GetWireVertexIndexes ()
 Returns a pre-initialized array of vertex indexes for wired display. More...
static void EnableGLStippleMask (const QOpenGLContext *context, bool state)
 Enables (OpenGL) stipple mask.
Detailed Description
A sub-mesh.
Equivalent to a CCCoreLib::ReferenceCloud for a mesh
Member Function Documentation
◆ addTriangleIndex() [1/2]
bool ccSubMesh::addTriangleIndex ( unsigned  firstIndex,
unsigned  lastIndex
Parameters
firstIndexfirst triangle global index of range
lastIndexlast triangle global index of range (excluded)
Returns
false if not enough memory
◆ addTriangleIndex() [2/2]
bool ccSubMesh::addTriangleIndex ( unsigned  globalIndex)
Parameters
globalIndexa triangle global index
Returns
◆ capacity()
unsigned ccSubMesh::capacity ( ) const
overridevirtual
Implements ccGenericMesh.
◆ createNewSubMeshFromSelection()
ccSubMesh * ccSubMesh::createNewSubMeshFromSelection ( bool  removeSelectedFaces,
IndexMap indexMap = nullptr
This method is called after a graphical segmentation or by ccMesh::createNewMeshFromSelection. It creates a new sub-mesh structure with the vertices that are tagged as "visible" (see ccGenericPointCloud::visibilityArray). This method will also update this sub-mesh if removeSelectedFaces is true. In this case, all "selected" triangles will be removed from this sub-mesh's instance.
Parameters
removeSelectedFacesspecifies if the faces composed only of 'selected' vertices should be removed or not
indexMapif an index map is provided, it will be used to 'translate' global indexes
◆ fromFile_MeOnly()
bool ccSubMesh::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
overrideprotectedvirtual
Loads own object data.
Called by 'fromFile' (recursive scheme) To be overloaded (but still called;) by subclass.
Parameters
ininput file
dataVersionfile version
Reimplemented from ccGenericMesh.
◆ getAssociatedCloud()
ccGenericPointCloud * ccSubMesh::getAssociatedCloud ( ) const
overridevirtual
◆ getClassID()
CC_CLASS_ENUM ccSubMesh::getClassID ( ) const
inlineoverridevirtual
Returns class ID.
Reimplemented from ccHObject.
◆ getColorFromMaterial()
bool ccSubMesh::getColorFromMaterial ( unsigned  triIndex,
const CCVector3 &  P,
ccColor::Rgba color,
overridevirtual
Parameters
triIndextriangle index
Ppoint where to grab color (should be inside the triangle!)
[out]colortexel color
interpolateColorIfNoTexturewhether to return the color interpolated from the RGB field if no texture/material is associated to the given triangles
Returns
success
◆ getMaterialSet()
const ccMaterialSet * ccSubMesh::getMaterialSet ( ) const
overridevirtual
◆ getOwnBB()
ccBBox ccSubMesh::getOwnBB ( bool  withGLFeatures = false)
overridevirtual
Returns the entity's own bounding-box (with local/shifted coordinates)
Children bounding-boxes are ignored.
Parameters
withGLFeatureswhether to take into account display-only elements (if any)
Returns
bounding-box
◆ getTexCoordinatesTable()
TextureCoordsContainer * ccSubMesh::getTexCoordinatesTable ( ) const
overridevirtual
◆ getTriangleMtlIndex()
int ccSubMesh::getTriangleMtlIndex ( unsigned  triangleIndex) const
overridevirtual
◆ getTriangleNormalIndexes()
void ccSubMesh::getTriangleNormalIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
overridevirtual
Parameters
[in]triangleIndextriangle index
[out]i1first vertex normal index (or -1 if none)
[out]i2second vertex normal index (or -1 if none)
[out]i3third vertex normal index (or -1 if none)
◆ getTriangleNormals()
bool ccSubMesh::getTriangleNormals ( unsigned  triangleIndex,
CCVector3 &  Na,
CCVector3 &  Nb,
CCVector3 &  Nc
) const
overridevirtual
Mesh must have triangle normals associated (see hasTriNormals)
◆ getTriangleTexCoordinates()
void ccSubMesh::getTriangleTexCoordinates ( unsigned  triIndex,
TexCoords2D *&  tx1,
TexCoords2D *&  tx2,
TexCoords2D *&  tx3
) const
overridevirtual
◆ getTriangleTexCoordinatesIndexes()
void ccSubMesh::getTriangleTexCoordinatesIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
overridevirtual
Parameters
i1first vertex tex coords index
i2second vertex tex coords index
i3third vertex tex coords index
◆ getTriGlobalIndex()
unsigned ccSubMesh::getTriGlobalIndex ( unsigned  localIndex) const
inline
Parameters
localIndexlocal index (i.e. relative to the internal index container)
◆ getTriNormsTable()
NormsIndexesTableType * ccSubMesh::getTriNormsTable ( ) const
overridevirtual
◆ getVertexColorFromMaterial()
bool ccSubMesh::getVertexColorFromMaterial ( unsigned  triIndex,
overridevirtual
Parameters
vertIndexvertex index inside triangle (i.e. 0, 1 or 2!)
returnColorIfNoTexturewhether to return the color from the vertex RGB field if no texture/material is associated to the given triangle
Returns
success
◆ hasColors()
bool ccSubMesh::hasColors ( ) const
overridevirtual
Returns whether colors are enabled or not.
Reimplemented from ccDrawableObject.
◆ hasDisplayedScalarField()
bool ccSubMesh::hasDisplayedScalarField ( ) const
overridevirtual
Returns whether an active scalar field is available or not.
◆ hasMaterials()
bool ccSubMesh::hasMaterials ( ) const
overridevirtual
◆ hasNormals()
bool ccSubMesh::hasNormals ( ) const
overridevirtual
Returns whether normals are enabled or not.
◆ hasPerTriangleTexCoordIndexes()
bool ccSubMesh::hasPerTriangleTexCoordIndexes ( ) const
overridevirtual
◆ hasScalarFields()
bool ccSubMesh::hasScalarFields ( ) const
overridevirtual
Returns whether one or more scalar fields are instantiated.
Warning
doesn't mean a scalar field is currently displayed (see ccDrawableObject::hasDisplayedScalarField).
◆ hasTextures()
bool ccSubMesh::hasTextures ( ) const
overridevirtual
◆ hasTriNormals()
bool ccSubMesh::hasTriNormals ( ) const
overridevirtual
◆ interpolateColors() [1/2]
bool ccSubMesh::interpolateColors ( unsigned  triIndex,
ccColor::Rgb color
overridevirtual
Parameters
Ppoint where to interpolate (should be inside the triangle!)
[out]colorinterpolated color
Returns
success
◆ interpolateColors() [2/2]
ccColor::Rgba color
overridevirtual
Parameters
Returns
success
◆ interpolateColorsBC() [1/2]
bool ccSubMesh::interpolateColorsBC ( unsigned  triIndex,
const CCVector3d &  w,
ccColor::Rgb color
overridevirtual
Parameters
wbarycentric coordinates
Returns
success
◆ interpolateColorsBC() [2/2]
ccColor::Rgba color
overridevirtual
Parameters
Returns
success
◆ interpolateNormalsBC()
bool ccSubMesh::interpolateNormalsBC ( unsigned  triIndex,
CCVector3 &  N
overridevirtual
Parameters
[out]Ninterpolated normal
Returns
success
◆ isSerializable()
bool ccSubMesh::isSerializable ( ) const
Returns whether object is serializable of not.
◆ normalsShown()
bool ccSubMesh::normalsShown ( ) const
overridevirtual
Returns whether normals are shown or not.
◆ onUpdateOf()
void ccSubMesh::onUpdateOf ( ccHObject obj)
This method is called when another object (geometry) is updated.
For internal use.
◆ refreshBB()
void ccSubMesh::refreshBB ( )
overridevirtual
◆ reserve()
bool ccSubMesh::reserve ( size_t  n)
Parameters
nthe number of triangles (references)
◆ resize()
bool ccSubMesh::resize ( size_t  n)
Parameters
◆ setAssociatedMesh()
void ccSubMesh::setAssociatedMesh ( ccMesh mesh,
bool  unlinkPreviousOne = true
Parameters
meshparent mesh
unlinkPreviousOnewhether to remove any dependency with the previous parent mesh (if any)
◆ setGlobalScale()
void ccSubMesh::setGlobalScale ( double  scale)
◆ setGlobalShift()
void ccSubMesh::setGlobalShift ( const CCVector3d &  shift)
Such a shift can typically be applied at loading time. Original coordinates are equal to '(P/scale - shift)'
◆ setTriangleIndex()
void ccSubMesh::setTriangleIndex ( unsigned  localIndex,
Parameters
globalIndexglobal index
◆ toFile_MeOnly()
bool ccSubMesh::toFile_MeOnly ( QFile &  out) const
Called by 'toFile' (recursive scheme) To be overloaded (but still called;) by subclass.
