CloudCompare 3D entities
Public Member Functions | Static Public Member Functions | Public Attributes | List of all members
ccCameraSensor::IntrinsicParameters Struct Reference
Intrinsic parameters of the camera sensor. More...
#include <ccCameraSensor.h>
 IntrinsicParameters ()
 Default initializer.
float horizFocal_pix () const
 Returns the horizontal focal pix. More...
static void GetKinectDefaults (IntrinsicParameters &params)
 Helper: initializes a IntrinsicParameters structure with the default Kinect parameters.
Public Attributes
float vertFocal_pix
float pixelSize_mm [2]
float skew
float vFOV_rad
float zNear_mm
float zFar_mm
int arrayWidth
int arrayHeight
float principal_point [2]
Detailed Description
Member Function Documentation
◆ horizFocal_pix()
float ccCameraSensor::IntrinsicParameters::horizFocal_pix ( ) const
inline
Warning
Be sure the pixel size values are correct!
Member Data Documentation
◆ arrayHeight
int ccCameraSensor::IntrinsicParameters::arrayHeight
Pixel array height (in pixels)
◆ arrayWidth
int ccCameraSensor::IntrinsicParameters::arrayWidth
Pixel array width (in pixels)
◆ pixelSize_mm
float ccCameraSensor::IntrinsicParameters::pixelSize_mm[2]
sensor pixel size (in real dimension, e.g. mm)
◆ principal_point
float ccCameraSensor::IntrinsicParameters::principal_point[2]
Principal point (in pixels)
◆ skew
float ccCameraSensor::IntrinsicParameters::skew
skew
◆ vertFocal_pix
float ccCameraSensor::IntrinsicParameters::vertFocal_pix
focal length (in pixels) - vertical dimension by default
◆ vFOV_rad
float ccCameraSensor::IntrinsicParameters::vFOV_rad
vertical field of view (in Radians)
◆ zFar_mm
float ccCameraSensor::IntrinsicParameters::zFar_mm
Far plane position
◆ zNear_mm
float ccCameraSensor::IntrinsicParameters::zNear_mm
Near plane position
The documentation for this struct was generated from the following files:
