qCC_io version 2.13.alpha (Qt) - 31 May 2022
CloudCompare standard I/O filters (file readers & writers)
BinFilter Member List
This is the complete list of members for BinFilter, including all inherited members.
BinFilter() (defined in BinFilter)BinFilter
BuiltIn enum value (defined in FileIOFilter)FileIOFilter
canSave(CC_CLASS_ENUM type, bool &multiple, bool &exclusive) const overrideBinFiltervirtual
CheckForSpecialChars(const QString &filename)FileIOFilterstatic
DEFAULT_PRIORITY (defined in FileIOFilter)FileIOFilterprotectedstatic
DisplayErrorMessage(CC_FILE_ERROR err, const QString &action, const QString &filename)FileIOFilterstatic
DynamicInfo enum value (defined in FileIOFilter)FileIOFilter
Export enum value (defined in FileIOFilter)FileIOFilter
exportSupported() constFileIOFilter
FileIOFilter(const FilterInfo &info) (defined in FileIOFilter)FileIOFilterexplicitprotected
FilterContainer typedefFileIOFilter
FilterFeature enum name (defined in FileIOFilter)FileIOFilter
FindBestFilterForExtension(const QString &ext)FileIOFilterstatic
GetDefaultExtension() (defined in BinFilter)BinFilterinlinestatic
getDefaultExtension() constFileIOFilter
GetFileFilter() (defined in BinFilter)BinFilterinlinestatic
getFileFilters(bool onImport) constFileIOFilter
GetFilter(const QString &fileFilter, bool onImport)FileIOFilterstatic
GetFilters()FileIOFilterstatic
HandleGlobalShift(const CCVector3d &P, CCVector3d &Pshift, bool &preserveCoordinateShift, LoadParameters &loadParameters, bool useInputCoordinatesShiftIfPossible=false)FileIOFilterstatic
Import enum value (defined in FileIOFilter)FileIOFilter
ImportFilterList()FileIOFilterstatic
importSupported() constFileIOFilter
IncreaseSesionCounter()FileIOFilterstatic
InitInternalFilters()FileIOFilterstatic
loadFile(const QString &filename, ccHObject &container, LoadParameters &parameters) overrideBinFiltervirtual
LoadFileV1(QFile &in, ccHObject &container, unsigned nbScansTotal, const LoadParameters &parameters)BinFilterstatic
LoadFileV2(QFile &in, ccHObject &container, int flags)BinFilterstatic
LoadFromFile(const QString &filename, LoadParameters &parameters, Shared filter, CC_FILE_ERROR &result)FileIOFilterstatic
LoadFromFile(const QString &filename, LoadParameters &parameters, CC_FILE_ERROR &result, const QString &fileFilter=QString())FileIOFilterstatic
NoFeatures enum value (defined in FileIOFilter)FileIOFilter
Register(Shared filter)FileIOFilterstatic
ResetSesionCounter()FileIOFilterstatic
SaveFileV2(QFile &out, ccHObject *object)BinFilterstatic
SaveToFile(ccHObject *entities, const QString &filename, const SaveParameters &parameters, Shared filter)FileIOFilterstatic
SaveToFile(ccHObject *entities, const QString &filename, const SaveParameters &parameters, const QString &fileFilter)FileIOFilterstatic
saveToFile(ccHObject *entity, const QString &filename, const SaveParameters &parameters) overrideBinFiltervirtual
setExportFileFilterStrings(const QStringList &filterStrings)FileIOFilterprotected
setImportExtensions(const QStringList &extensions)FileIOFilterprotected
setImportFileFilterStrings(const QStringList &filterStrings)FileIOFilterprotected
Shared typedefFileIOFilter
unregister()FileIOFilterinlinevirtual
UnregisterAll()FileIOFilterstatic
~FileIOFilter()=default (defined in FileIOFilter)FileIOFiltervirtual
