after 2.14 beta update,
CC can't read .glb file.
Please handle this issue. Thanks a lot.
2.14 beta can't read .glb file.
- issue abot .glb file.
- issue.png (92.67 KiB) Viewed 76172 times
Re: 2.14 beta can't read .glb file.
Yes, this format is not supported by CloudCompare. That's not an 'issue' per se ;)
But previous version can open .glb file.
- glb issue.png (33.33 KiB) Viewed 75929 times
Ah, it must have been managed by the Mesh I/O plugin then. This plugin was not compiling with Qt 6 anymore, but I managed to fix it I think (I haven't been able to test).
Can you test this new version: https://www.cloudcompare.org/release/Cl ... up_x64.exe
(sadly it's not signed with a certificate, so you may have to convince Windows that it's safe to run)
It works. Thanks a lot. :)
Ran into the same thing on 2.14. Until GLB support is back, the workaround that costs the least effort: convert the GLB to OBJ first and open that instead. furnimesh.com/convert/glb-to-obj does it in the browser, no install, and the scale came through correctly for me, so measurements in CloudCompare stay trustworthy. PLY via a converter also works if you need vertex colors, but for a textured mesh the OBJ route was the cleaner import.
