Cross Section tool problems
Posted: Tue Jan 16, 2018 9:59 am
by AEA
I have a problem with the Cross Section tool. It never happened to me before... When I activate it and everything is ready to work with it I try to adjust the box and instead of interacting with the arrows, the mouse just rotates the cloud!! I cannot change the box with the mouse any longer!!
I've installed the latest versions (2.9.0, 2.9.1 and 2.10a) and it happens. I reinstalled version 2.8.1 and keeps happening!!
Is it me or there is something I could do??
Many thanks.
Re: Cross Section tool problems
Posted: Tue Jan 16, 2018 7:43 pm
Hum, it looks like an OpenGL 'picking' issue then. Have you updated your driver recently? What graphic card are you using by the way?
Posted: Wed Jan 17, 2018 8:36 pm
by AEA
I have a NVIDIA Quadro K2200 but I have not update the driver recently (at least consciously).
I always have estrange things happening to me...!
Thanks for your assistence!!
Àlex
Posted: Wed Jan 17, 2018 8:44 pm
Do you also have an integrated Intel card maybe? If yes, does CC uses the Quadro or this one? (you can see that in the Console when CC starts)
Posted: Wed Jan 17, 2018 9:35 pm
by AEA
I'm not sure if I also have an integrated one. However, CC uses the NVIDIA.
Posted: Thu Feb 08, 2018 5:06 pm
by AEA
Yes!! It was a driver problem. I updated it and it works correctly again.
Thank you!
Posted: Tue Jul 31, 2018 10:29 am
by AEA
Hi, I'm having the same problem again... However, this time I updated the driver and the problem was not solved... It is very annoying since I cannot use the Cross section tool and I would need to!!!
Is it only me???
Any suggestion? How should address the NVIDIA support center? What should I ask them??
Posted: Thu Aug 02, 2018 11:11 pm
Which graphic card do you have? And what kind of screen(s)?
Posted: Fri Aug 03, 2018 11:22 am
by AEA
Nvidia Quadro K2200 and a Acer DVI 24" screen.
But the question it worked fine and all of a sudden it stopped working...
Posted: Fri Aug 03, 2018 11:25 am
by AEA
Actually, I'm recently using 2 screens. Could this be the reason? But, no.... I having the same issue at home with a single screen and with different graphic card...
