[2.14.beta] Saving to LAS/LAZ zeroes the scale of scaled extra-bytes fields
jlin
Post by jlin »
In CloudCompare v2.14.beta (2026OCT24 build, Windows 10 64-bit), saving a cloud to LAS or LAZ destroys any extra-bytes field that has a scale factor. The field is still in the saved file, but when the file is reopened every point reads 0.
What happens
  • Loading is fine: an int16 extra-bytes field with scale 0.0001 shows the correct values (-0.499 to +0.500 in my test file).
  • On save, the extra-bytes descriptor keeps the "scale" option bit but the scale is written as 0.0. If the input declared a no-data value, that bit is dropped too.
  • The stored integers become 32767 for every positive value, -32768 for every negative value and 0 for exact zeros, so only the sign survives. It looks as if each value is divided by the zero scale and clamped to the int16 range.
  • Reopening the saved file in CloudCompare shows the field as 0 on every point.
Steps to reproduce
  1. Use the attached file. It is a 32 x 32 grid with one int16 extra-bytes field "displacement", scale 0.0001, ramping from -0.5 to +0.5.
  2. Run:
    CloudCompare -SILENT -AUTO_SAVE OFF -NO_TIMESTAMP -O scaled_int16.laz -C_EXPORT_FMT LAS -EXT laz -SAVE_CLOUDS FILE scaled_int16.cc_saved.laz
  3. Open scaled_int16.cc_saved.laz: "displacement" is 0 everywhere.
The same happens with -EXT las, whether or not the cloud is cropped first, and when saving from the GUI. I first hit it by segmenting a cloud and saving the selection as LAZ.
Extra-bytes descriptor before and after the save, read with laspy:
input  scaled_int16.laz           data_type 4 (int16)  options 0b11000  scale 0.0001  offset 0.0   raw values -4990 ... 5000
saved  scaled_int16.cc_saved.laz  data_type 4 (int16)  options 0b11000  scale 0.0     offset 0.0   raw values only -32768, 0, 32767
Field types I tested
  • int16, scale 0.0001: broken
  • int16, scale 0.0001, no_data -32768: broken (no_data bit also dropped)
  • int32, scale 0.0001, no_data: broken
  • int16, no scale: OK, raw values identical
  • float32, no scale: OK, values identical
  • Same scaled int16 cloud exported to PLY instead: OK
I can send the input and saved files, or test a newer build.
scaled_int16.zip
(1.03 KiB) Downloaded 508 times
Re: [2.14.beta] Saving to LAS/LAZ zeroes the scale of scaled extra-bytes fields
Thanks for the report. We will investigate (you could even open a github issue if you want to follow this more closely).
This should be fixed now in the latest 2.14.beta version!
