Save As > FBX
Steve L~
Save As > FBX
Post by Steve L~ »
What are the requirements for saving a BIN file as a FBX - I cant seem to get FBX as a save option at all when either selecting a series of meshes or selecting the top level branch of a BIN file that contains only meshes.
I feel sure I’ve done this before !
Thanks,
Re: Save As > FBX
Oops, I totally forgot to compile the latest 2.10.alpha version with the FBX SDK!
I've just updated the online version.
Steve L~
Re: Save As > FBX
Post by Steve L~ »
Great thanks Daniel,
I thought I was going crazy.....
Much appreciated !
DJSLRP
Re: Save As > FBX
Post by DJSLRP »
I am also trying to export FBX, but the option is not available. However, I am just trying to export point cloud and RGB (if supported). The File I/O wiki page says it should be supported. I assume that >1 means that more than one point cloud can be saved in the file? Please advise.
Re: Save As > FBX
FBX is now back in the official 2.10 versions (online).
And FBX only supports meshes. If it's written otherwise in the documentation, then it's a mistake! (EDIT: that's fixed now, thanks for the feedback ;)
DJSLRP
Re: Save As > FBX
Post by DJSLRP »
It would be fantastic if you did enable point cloud support for FBX. VFX industry standard compositing software NUKE appears to support that format for import...
https://learn.foundry.com/nuke/8.0/cont ... metry.html
