default active scalar field
nir
Post by nir »
I have many las files which are already classified. I would like to examine the classification without being required to change the active scalar field manually for each file. Is there a way to change the default active scalar field.
Thanks.
Re: default active scalar field
Hum, sadly not (appart if you only load the classification field?).
Of course if you hack the code it might be easier...
nir
Post by nir »
Loading only the classification field seems to do the work for now.
Thanks.
