How to calculate stockpile volume?
David_Nilsdotter
Post by David_Nilsdotter »
Hi.
I am new to CC, and I am in the process of calculating the volume between a point cloud and a mesh object. It appears to be very powerful, and I think I will have great use of it.
What I want to do is to calculate the stock volume between an area (mesh) and a point cloud. The volume is limited by the mesh area, and is based on the height difference between the point cloud and mesh. Please see https://support.pix4d.com/hc/en-us/arti ... #gsc.tab=0 for a visual representation of what I want to accomplish.
I want to do this through the command line. And I have observed the command:
CloudCompare -o cloud1.bin -o mesh.obj -c2m_dist
and it generates a bin file that contains the distance between the mesh and point cloud that is represented as a height field.
So I am wondering the following things:
  • What is the format of the resulting bin file? (and can I get the resulting artifacts in ASCII format?)
  • Is this the correct way to go about finding the volume?
  • If not, how can CC help me do this?
Also, any references to the calculation (algorithm name, paper, pages) would be very helpful for me to get a better understanding of what is going on.
Thanks for a great work.
Re: How to calculate stockpile volume?
To compute the volume, you'll have to use the... 2.5D Volume calculation tool ;). That's the only algorithm available for now.
This algorithm works between two clouds, so you'll have to convert your mesh to a cloud first (with -SAMPLE_MESH). Then use the -VOLUME option to compute the volume. See more info here:
- http://www.cloudcompare.org/doc/wiki/in ... _line_mode
- http://www.cloudcompare.org/doc/wiki/in ... .5D_Volume
There are otherwise several options to change the output file format, etc.
