segment and move
mirijovsky
segment and move
Post by mirijovsky »
Dear Daniel,
I have a point cloud of a large area and I need to cut and delete some points along the whole area. But my select has to be very precise so I need to zoom in. Is it possible move the cloud during the using "Segment" tool? If not it is good feature request :)
Thank you.
Jakub
Re: segment and move
Not really... You can pause the tool anytime (with the 'pause' button, or the space bar) so as to be able to move the cloud but it will stop the edition of the current polygon I believe.
However, as you can always select the outside or the inside of a polygon, you can precisely remove the points inside a (small) area instead of trying to keep the points inside a large one?
