Saving indices for closest distance points in Command line
Ghazanfar
Post by Ghazanfar »
Hello Danial,
Let me first mention that it is an amazing work that you have done. It helps me a lot in my research work. I want to ask if there is any way in the command line to save the indices of closest points from compared point cloud that have been used to compute the nearest distance in the reference point cloud. I have seen in GUI that there is an option in the distance computation "Closest Point Set" that gives only the closest points. Is it possible in command line? For me, the goal is to compare the deviation of the normals for the points that have been used in closest distance computation. I need to know which two points are used in distance computation to get their associated values of normals for deviation computation.
I hope I explained my question in the right way.
Thank you for your help
Re: Saving indices for closest distance points in Command line
Well, it's always possible to add new functionalities to the command line (we are "open" to this). But regarding who will do that and when it's impossible to say (we all do this on our free time or for our own research activities). I'll add this to the huge TODO list.
Meanwhile if you know a motivated C++ developer, then it can be more efficient to convince him to help you reach that goal (and we can give him/her directions of course).
