something wrong when using ccGLCameraParameters
kasper
Post by kasper »
I want to get the ccGLCameraParameters data.
 ccGLCameraParameters camera;
 glWindow->getGLCameraParameters(camera);
but there's something wrong.
"QCC_DB_LIB.lib(QCC_DB_LIB.dll):-1: error:
 LNK2005: "public: virtual void __cdecl ccGLMatrixTpl<double>::toIdentity(void)" (?toIdentity@?$ccGLMatrixTpl@N@@UEAAXXZ) 已在 mainwindow.obj 中定義過了"
it already defined in mainwindow.obj
so I remove all code .
Only left with
CreateGLWindow(glWindow, widget);
it still error.
I found that the problem is "ccGLMatrixd"
#include <ccGLMatrixTpl.h>
ccGLMatrixd m;
then the same error.
but no error when using "ccGLMatrix"
I also can not find "ccGLCameraParameters" in document?
How to fix it? Thanks.
kasper
Re: something wrong when using ccGLCameraParameters
Post by kasper »
I don't know how , LNK2005 disappeared Linux OS.
But now I got a new problem,
when I'm using
ccGenericPointCloud::VisibilityTableType *visibilityArray = cloud->getTheVisibilityArray();
it was error.
I click into getTheVisibilityArray() function, and in header file,
its return type is ccGenericPointCloud::VisibilityTableType not ccGenericPointCloud::VisibilityTableType *
but I serach in document-api online it return ccGenericPointCloud::VisibilityTableType *
why they are different?
Second, after I get the visibility array, visibilityArray is not a null object but its size is 0.
should I do any setting before it?
it's my code.
    m_glWindow_->getGLCameraParameters(camera);
    const double half_w = camera.viewport[2] / 2.0;
    const double half_h = camera.viewport[3] / 2.0;
    ccGenericPointCloud::VisibilityTableType *visibilityArray = &c->getTheVisibilityArray();
    assert(visibilityArray);
    unsigned cloudSize = c->size();
    qDebug() << "visibilityArray" <<  visibilityArray->size();   // it return 0
    for (int i = 0; i < static_cast<int>(cloudSize); ++i)
        qDebug() << "cloudSize"<< cloudSize;
        if (visibilityArray->at(i) == POINT_VISIBLE)            // it will runtime error because of its size.
            const CCVector3* P3D = c->getPoint(i);
            CCVector3d Q2D;
            camera.project(*P3D, Q2D);
            CCVector2 P2D(	static_cast<PointCoordinateType>(Q2D.x-half_w),
                            static_cast<PointCoordinateType>(Q2D.y-half_h) );
            bool pointInside = CCLib::ManualSegmentationTools::isPointInsidePoly(P2D, m_segmentationPoly_);
            visibilityArray->at(i) = ( false != pointInside ? POINT_HIDDEN : POINT_VISIBLE );
The online code documentation is a little bit old (well, actually it's very old). The new API indeed returns a reference on the 'visibility table':
https://github.com/CloudCompare/CloudCo ... oud.h#L171
And before using it, you have to actually allocate it (with resetVisibilityArray) and then populate it (not sure what you want to do with it).
