Scan Position and Rotation of the Laser Scan from a Leica 360 BLK
smoluck
Post by smoluck »
I'm wondering i f there is a fast way to output the Scan Position and Rotation of the Laser Scan (from a Leica 360 BLK).
Actually i found that the Radian metadata in the pose / STRUCTURE could be used to get the Pos and Rotation.
Is there an export plugin to get those out ? like in this example ?
Best regards, Smoluck
Re: Scan Position and Rotation of the Laser Scan from a Leica 360 BLK
Sadly no.
The latest version of CC (2.11.alpha) will automatically extract the "sensor" information from E57 files (as a "TLS sensor" object, below the corresponding scan cloud).
But this sensor object doesn't keep the rotation angle values as is, and you can't export them...
smoluck
Post by smoluck »
Thanks for your reply Daniel.
i will deal with this in a different way.
