Mesh in Cloud compare and python script
I have been trying to compare the result of Poisson Reconstruction algorithm in cloudcompare and open3d. Im attaching the images. is there any way to improve the result in open3d?
- cloudcompare_mesh.png (466.55 KiB) Viewed 19063 times
- mesh_open3d.png (416.87 KiB) Viewed 19063 times
Re: Mesh in Cloud compare and python script
Yes you have to generate the "density" scalar field and then remove the triangles corresponding to low density areas.
See https://www.cloudcompare.org/doc/wiki/i ... n_(plugin) (last section, about "Using the output density").
thanks daniel for reply. I can successfully improve the result in cloudcompare. now the thing is If you have a closer look on both the images that I attached the mesh through cloudcompare is very sharp but the one through open3d library of python is not very good. The algorithm to generate the mesh in both the cases is same "Poisson reconstruction". Do you have any idea how can I achieve the same result in open3d?
Oh sorry, I missed the real question ;)
Well, is it the same version of the algorithm? We use the most recent one (well, depending on the version of CC of course): http://www.cs.jhu.edu/~misha/Code/Poiss ... sion12.00/
And have you used the same parameters? Even the advanced ones?
I used the following paramters
mesh, densities = o3d.geometry.TriangleMesh.create_from_point_cloud_poisson(pcd, depth=10, width=0, scale=1.1, linear_fit=True)
I changed some of these paramters but I failed to found the options like setting boundary as free , neumann and Dirichlet.
I also was not able to find the setting for getting the output as density etc etc
do you know how can set these with open3D?
or could you tell which language and libraries you are using to build this software?
;) I know that could be a bit nosy question to ask :D
I dig into source code of possion recon on github and on the inspection of source code I found
The default options of Poisson recon in open3D are
sample per node 1.5
full depth 5
point weight 2
Boundary Neuman
and in Cloud compare
I use the options
samples per Node 1.5
full depth 5
point weight 4.06
Boundary Neuman // change it too to match
only difference is the point weight so I changed the point weight in cloud compare as I dnt know how can I change it in python (I search for the source code in site package of python but found no source code). but there was no much difference on resulting mesh in cloud compare.
sample per node 1.5
full depth 5
point weight 2
Boundary Neuman
I use the options
full depth 5
point weight 4.06
One thing that might be misleading here is also the way colors are interpolated inside the triangles? They look a little bit funky in the open3D capture... What I mean is that maybe the mesh structure is the same, but the colors are either not interpolated correctly, or not displayed properly?
you might be right about the color interpolation.
But what I found out is in open3d the normal computation does not follow the orientation of normal. so by setting everything the same I computed the normal (unchecking the orientation through the spanning it) in CC and was able to replicate the result like open3D.
