Command Line Export - Specify which scans to export?
Chrono9084
Post by Chrono9084 »
I am dealing with an issue where I get an error stating that I do not have enough memory to complete the export process. I get the same error if I try opening the cloud in CC. This is despite having 64GB of ram on this machine.
Is there any way to specify a certain number of scans to export? I figured I could do 1-20...then 21-40...etc until I am done if this was a possibility.
If it is not, do I have any other options outside of putting even more memory in my machine?
The scan in question is a 259GB E57 file....yeah...its large. Also, I am an end user so I do not have access to the original scan data or else this would not be an issue at all.
Re: Command Line Export - Specify which scans to export?
Very large indeed ;)
And saldy no, there's no way in CC currently to skip some scans in E57 files.
You can maybe try to expand your virtual memory instead? (and then take a break as the process might take a loooooong time).
