How to find area of flat mesh?
DA523
Post by DA523 »
I flattened a mesh by scaling z to 0
I need to find MESH FLAT AREA
Please check attached STL file
area.zip
(979 Bytes) Downloaded 528 times
Re: How to find area of flat mesh?
Have you tried the 'Edit > Mesh > Measure surface' tool? (it should work fine as long as the triangles are not overlapping each other after the mesh has been 'flatten').
(on your example mesh, it gave me 1260.28 square units)
DA523
Post by DA523 »
Yes this is exactly the solution
Thank you
