Hello
When I compile my own plugins, the plugins generated in the build directory after make do not need the nxlib library,
but the plugins generated after make install need the nxlib library,
why is this?
Can you tell me how to hold this library?
Thank you!
nxlib library file not found
- nxlib.png (13.17 KiB) Viewed 3479 times
Re: nxlib library file not found
I found the solution that
Just download and install this
https://www.ensenso.com/portfolio-item/ensensosdk
But I don't know why I can run it directly after make, but I need this library after make install?
