Split by Oc Tree level
pedroiserte
Post by pedroiserte »
Hi everyone!
Is there any way to split a Pointcloud into several pointclouds, one per each "Bounding Box" of an Octree Level? It would be exceptionally usefull for me to have several smaller pointclouds instead of one large.
Thanks!
Re: Split by Oc Tree level
You can use the 'Cross section' tool, with the 'Repeat slice extraction' option: https://www.cloudcompare.org/doc/wiki/i ... r_contours
