Hello every one
i have two sets of point clouds one from laser scanner and another from Photogrammetry. the point cloud is for road surface texture (pavement).
As the pavement is flat surface it has not got any edges or vertices that you can use for registration. As a result, I am using some target or markers on the surface to be used as sharing point between the two sets. Although, I can export both point clouds to CC successfully with their texture but during registration of the two point clouds. the target points are losing their texture and I am not able to align the markers because I can only see the vertices without texture. Can any one please let me know how to overcome this problem......
Regards
Registering two point clouds
Re: Registering two point clouds
I couldn't reproduce the issue: I loaded two points clouds (with RGB colors --> this is what you are calling texture, right?) and I launched the 'Align (point pair picking)' tool (I guessed this is what you are trying to use because you can't use the ICP registration process, am I right again?). The clouds then lose their color just the time of selecting the reference and the compared one, then they get back to their original state (see image below).
If one of the 'cloud' is in fact a mesh with a real "texture" (coming from Photomod for instance), then you'll need to convert first the texture to RGB colors (Edit > Mesh > Convert texture/material to RGB).
- Screenshot
- cc_point_pair_registration.jpg (231.56 KiB) Viewed 13328 times
Hello Daniel
thanks for quick reply, actually, I am aware of that type of registration. In my case I have a flat surface which there are no edges or sharp features that both surfaces can share. I have attached for you a copy of the surface. So as you can see, thee are markers on the surface which I want to use them for registering the two surfaces. So when I use the align registration, these markers lose their texture temporarily. In this case it is difficult or impossible to find the markers. Is their any ways to first write down the xy and z of sharing points.
cheers
cheers
- Untitled.jpg (169.32 KiB) Viewed 13327 times
So finally, were the colors coming from a real mesh "texture"? If yes, did you try to convert it to RGB colors?
Yes it was from mesh and not from the vertices, Yes you are right I overcome this problem by RGB conversion
