3D triangulated model
Hajos
Post by Hajos »
Hello All. Please, how can I make a 3D triangulation model? I have a point cloud from scanning the tunnel and I need to make it a 3D triangulation model. I tried it through poissonRecon. But I was not satisfied with the result. Because if I compared the network with the points I created it the deviations were somewhere over 3 cm. Maybe I made a mistake somewhere in normalization or in defining parameters, but I tried different variants and the result was always the same. I need to make a 3D model so that my points from the scan are the "corners" of the triangles. So if I compare the points with the network, let the deviations be minimal. Can you please achieve this nicely? I will be very grateful for any help.
Re: 3D triangulated model
Have you increased the octree level/depth when reconstructing with Poisson? Because the lower it is, and the more 'approximate' the result will be (as you basically have less and larger triangles).
Hajos
Post by Hajos »
Hello Daniel,
I've figured it out. I have the best solution when I used triangulated surface (normals) and I increased the weight of the points in Poisson. Have a nice day :)
