I want to compare a stepfile and a pointcloud with each other.
But when I open the stepfile it does'nt show as I want to, only points at the radius and the edge.
I can compare them but I also want to show a profile line in a section view, but the step model doesnt show a proper "line".
So is it possible to show points of the whole model?
See attatched pictures of a similar example as i want to compare.
// Mikael
Imported step
Imported step
- Cylinder_section view.JPG (14.6 KiB) Viewed 2651 times
- Cylinder_stepmodel.JPG (21.32 KiB) Viewed 2651 times
- Cylinder_cloudcompare.JPG (39.36 KiB) Viewed 2651 times
Re: Imported step
Hum, that's weird, it's as if OpenCascade was failing to convert the STEP file to a proper mesh.
Can you maybe share the file with me? (admin [at] cloudcompare.org)
