Window App Size and Position
All about Windows versions
OxeStone
Post by OxeStone »
The latest version opens maximized, and I cannot find a way to change this behavior. CC doesn't remember the size and position of the last window opened, either. I have a large monitor, and opening CC maximized every time is somewhat annoying. Please advise. Thank you.
Re: Window App Size and Position
Yes, that was because of a bug that was making CC freeze on some setups when restoring the window on the wrong screen... I'll add an option to choose whether the screen should be restored or not on startup. This will be available in the next alpha release (hopefully online in a few days)
OxeStone
Post by OxeStone »
Thank you!
Ok, the latest 2.13.alpha version has been updated. It should now remember the window size and position (or at least you can control this behavior via 'Display > Restore window geometry on startup')
OxeStone
Post by OxeStone »
Thank you. It's working as expected.
