Fill gaps in a point cloud
un2jay
Post by un2jay »
hello,
I'm trying to fill in gaps in a point cloud data. is there a tool i can use in Cloud Compare to do this?
Here is an example of how the hole looks like.
Re: Fill gaps in a point cloud
I searched for 'fill gaps' on the forum and found: https://www.cloudcompare.org/forum/view ... 593#p26593
DA523
Post by DA523 »
You can use same polyline to trim new pointscloud generated by sampling poission mesh
If you need more control of hole (gap) closing , Blender can help a lot
please check attached bin CC file
DA523
Post by DA523 »
2.zip
(130.03 KiB) Downloaded 1213 times
DA523
Post by DA523 »
Meshing by simple Delaunay (best fitting plane) is possible too
(meshing, sampling ,segmenting then merging into original pointscloud)
un2jay
Post by un2jay »
DA523 wrote: Sun Nov 27, 2022 5:01 pm Meshing by simple Delaunay (best fitting plane) is possible too
Thanks ! This helped a lot :)
