CANUPO differences between GUI/Command Line
Test
Re: CANUPO differences between GUI/Command Line
If the parameter is properly read, you should see in the (command line) console:
I wonder if another issue might be with the Global Shift? Can you try with the 'AUTO' option?
Confidence threshold set to XXDaniel, CloudCompare admin
test
Hard to tell... What about the Global Shift, is it the same? Or maybe it's just a display thing?
