Volume change calculation
AbolDH
Post by AbolDH »
Hello
I have two different point clouds from a similar stockpiles that thaken from different times.
Now i wanna calculate the volume change between these two as a pointcloud difference or mesh difference or dem difference.
How can i do that?
Please examine for a amateur user.
Re: Volume change calculation
That's not easy, but I would use the '2.5D Volume calculation' tool between 2 clouds directly. See https://www.cloudcompare.org/doc/wiki/i ... .5D_Volume
Well, assuming the clouds are 2.5D...
DA523
Post by DA523 »
volume calculation is sometime tricky
Can you attach here in zip file pc or mes resample you project so I can advise
AbolDH
Post by AbolDH »
DA523 wrote: Fri Aug 25, 2023 2:59 pm volume calculation is sometime tricky
tnx i just wanna know the prosses
