Matlab question
cTPANEK
Matlab question
Post by cTPANEK »
Is it possible to call CC in Matlab to calculate distance error between two ply file?
Re: Matlab question
Well, the only way I see is to call it via the command line. But then you'll have to open the resulting file created at the end of the process. Ideally you will have chosen the ASCII format as output to make things easier.
