Liblas exception: 'version minor out of range" error
Posted: Wed Sep 16, 2015 12:44 pm
by fg80hu
I receive this error message when dropping a las file in ( both v2.6.2b and v2.6.0):
- Displayed first....
- cc_error1.JPG (13.47 KiB) Viewed 20981 times
after clicking OK here, displayed this one:
- Displayed after clicking OK at first
- cc_error2.JPG (19.79 KiB) Viewed 20981 times
The same thing thing occurs if I compress the las file to laz with laszip.exe, the .laz file also drops this message.
Thanks!
Re: Liblas exception: 'version minor out of range" error
Posted: Wed Sep 16, 2015 1:15 pm
Indeed, this is because Liblas (the library we use to load LAS files) doesn't support the version 1.4 of LAS/LAZ format (the one with full-waveform).
If you don't have any full waveform data, I bet lastools must have an option to downgrade the file to version 1.3?
Posted: Thu Sep 17, 2015 6:45 am
by fg80hu
So it is. Thank you.
Posted: Sun Oct 04, 2015 8:44 pm
by Dimitri
Just for information : Actually, las 1.3 can also include full waveform information. If you try to load a las 1.3 with FWF data embedded, Cloudcompare will report an error
Posted: Mon Oct 05, 2015 4:49 pm
I don't know if liblas if still actively supported... I believe that PDAL is more up-to-date but I really miss the time to look at this right now :(
Posted: Tue Nov 29, 2022 10:42 pm
by Billy_G
I have this exact issue. Running CloudCompare v2.7.0. Can anyone explain how to fix this in layman's terms? Thanks in advance.
Posted: Sat Dec 03, 2022 11:27 am
CloudCompare 2.7.0?! This is absolutely not supported anymore ;)
