Lighten RGB
Posted: Fri May 27, 2016 2:18 pm
by Andreas
I have a point cloud with rgb color. The images, take by the scanner, are very dark.
[img]
[/img]
Is there any possibility in CC to lighten up the color?
The P.C.V (Amibien Occlusion) gives a good grayscale color, but I need it in rgd.
[img]
[/img]
Regards Andreas
Re: Lighten RGB
Posted: Fri May 27, 2016 3:44 pm
To lighten the colors, you should use the 'Edit > Colors > Levels' tool (http://www.cloudcompare.org/doc/wiki/in ... s%5CLevels). It works just as the same tool in Photoshop.
Otherwise, to convert the PCV scalar field to colors, you just have to call 'Edit > Scalar fields > Convert to RGB'.
