My goal is to make a panorama or minimum Cube faces (left,right, top, down, front, back) from a desired position by using CC. Its nothing new ....
I created scanner from desired position, but couldn't get desired results.
Please see attached images.
Is there any work flow to follow to get desired projection ?
Making Cube faces (6) from desired position
- step1.JPG (97.61 KiB) Viewed 3839 times
- Result1.JPG (151.99 KiB) Viewed 3839 times
- object.JPG (81.98 KiB) Viewed 3839 times
Re: Making Cube faces (6) from desired position
Shouldn't use Projective Camera sensors instead?
