Pan in Trace Polyline command
Posted: Wed Apr 12, 2017 2:36 pm
by geolux
Hi Guys
When I'm using the function "Trace Polyline" for draw on Points cloud and I use "Pan" with right click mouse, command are interrupted and green poly stop to edit.
I'm mistaking some things?
Is there a solution?
Re: Pan in Trace Polyline command
Posted: Thu Apr 13, 2017 7:33 am
by geolux
It Seems that the right click is the end of the drawing command and the same time the "pan" command. So when I want move the view in other point of model and I use right click I can't continue to draw on points cloud
Posted: Thu Apr 13, 2017 7:39 am
Indeed, right clicking is used to stop editing (same mechanism as for the interactive segmentation tool). Not sure how to deal with this properly yet!
Posted: Thu Apr 13, 2017 8:45 am
by geolux
I'm thinking that a rapid solution could be to change the end command to drawing tool. For example "return" or only clicking on the confirm icon, like attached image.
But ... why during the work this icon is disable?
Posted: Sat Apr 29, 2017 6:38 am
by geolux
do you think it is easy to do it, in this mode?
Posted: Mon May 01, 2017 9:12 am
The issue is not how easy it is (well not only at least). The real thing that matters is who will do it and when ;)
Posted: Thu Sep 28, 2017 2:13 am
by framed
Hi Daniel, would a quick solution to this issue be to implement keyboard shortcuts for panning?
Posted: Fri Sep 29, 2017 4:26 pm
Okay, I added a CTRL + right click shortcut. As well as a 'continue' button in case the user mistakenly closes the polyline. It should do the trick.
I'll let you test the latest 2.9 beta version (online).
Posted: Mon Oct 02, 2017 8:49 pm
by framed
This is working nicely, thanks Daniel!
