CloudCompare freeze when Subsample by active coordinate Scalar Field
Posted: Wed Dec 13, 2017 2:17 pm
by Jacoban90
Hi CloudCompare Community:
I recently discovered the program by another user and I found it very practice.
My question is related to the subsample tool. My objective is to modulate the distance between points by using a coordinate scalar field, concretally in the z direction. When I go to edit;subsample;go to space mode and check "Use active scalar field". maximum and minimum space. and press "Ok", the program freezes.
Thank you all in advance
Best Regards
Jacob
Re: CloudCompare freeze when Subsample by active coordinate Scalar Field
Posted: Wed Dec 13, 2017 9:32 pm
Which version are you using? Moreover, make sure to use 'realistic' values, as if the radius become very big for some values it may take a long time to process.
Posted: Thu Dec 14, 2017 12:38 pm
by Jacoban90
I'm using the 2.9.1 version. I proved with diferent distances but it doesnt change nothing.
I attach you below the link with the .stl mesh and the cloudcompare file with the attachment. I cannot upload directly to thew forum. I dont know why.
https://drive.google.com/open?id=14EmZK ... k09oKJIgHu
https://drive.google.com/open?id=19bPKj ... AtjTXVNj_D
Best Regards
Jacob
Posted: Fri Dec 15, 2017 8:31 am
Well, I'm not sure what you are trying to achieve with a mesh (in "Cloud"Compare ;). However I assumed you were trying to resample the vertices?
Here's what I got (after setting the Z coordinate as scalar field):
It works fine on my side. And it works also if I do this on a sampled version of the mesh (plane).
Posted: Fri Dec 15, 2017 9:53 am
by Jacoban90
Yes, I created the mesh in another program. Then I imported in cloudcompare to extract the vertices.
I defined a active scalar field to the z coordinate.
https://drive.google.com/open?id=1JgVJn ... jR7Un0whtT
I created the subsample using the "z scalar field" at the same way of you.
https://drive.google.com/open?id=1e_GhZ ... dgKKfBlQg3
But when I press ok the program freezes and doesn´t seem to work.
https://drive.google.com/open?id=19e15o ... ipeMJv8f8E
Best Regards
Jacob
Posted: Fri Dec 15, 2017 10:27 am
Can you try with the 2.10.alpha version then?
Posted: Fri Dec 15, 2017 11:24 am
by Jacoban90
Perfect the problem was related to the version of the program. In 2.1 works fine. Thank you very much.
Best Regards
Jacob
