Export Clouds with given filename
Ingsayyad
Post by Ingsayyad »
I am trying to save merge cloud as TEST.e57. How can I do it?
"C:\Program Files\CloudCompare\CloudCompare" -AUTO_SAVE OFF -o C:\CloudComparetest\r02.las -C_EXPORT_FMT E57 -SAVE_CLOUDS  % ---WHERE CAN I ADD NAME OF FILE---%
Re: Export Clouds with given filename
For now there's no option to specify the output filename in the command line tool of CloudCompare. You can only choose whether the timestamp should be added or not (see the -NO_TIMESTAMP option).
