Area of Irregular Shapes
beriv89987
Trying to find the area of this polyline/roof face. When I create a mesh, it makes the 4 sided shape and the calculation appears off. What would be the most simple way to do this? Thanks!
- Capture45.JPG (186.13 KiB) Viewed 4275 times
Re: Area of Irregular Shapes
Hum, not sure what to do. Can you try to segment the part out (with the scissors tool) and then fit a 'facet' on the segmented part? I believe one of the entities composing the facet has the 'surface'. Not sure if it will fit your needs however.
