Registration TLS Surveying
Posted: Fri Dec 07, 2018 7:45 am
Good morning Group
I'm testing the use of CC for register my ZF Scans without property ZF's Software.
There are differents way to do it.
But for a faster site survey the best is don't use (or little use) of topography mesures on targhet.
So, in this case I think that the better thingh, is put the scan position on site with the aim to use cloud to cloud orientation.
The Cloud to Cloud algoritm in CC work very well (with the correct setting) but I have a problem when I wont to orient my group of LS acquisitions, in a specific System Referent, using "align by pickin points pairs" command.
For do it, must I before merge the set of LS position, and them roto-traslate it on points pair? If it is the only way, This procedure in some case not is recommended because sometime is needed to leave separated the scan position, or in other coases the big number of scan position would make the merged file too big to do worked.
Have you other suggests?
Thank you
Thank you
