How to separate e57 files
Bouldster
Post by Bouldster »
I have one e57 file that is made up of 15 scans. I would like to split this up into 15 seperate e57 files. Is this possible with CC?
I found this topic in the search https://www.danielgm.net/cc/forum/viewtopic.php?t=2709
However on trying it out it is not working. My code is: CloudCompare -O Chatham Station internal.e57 -C_EXPORT_FMT E57 -SAVE_CLOUDS
The error message is saying : {Load} Can't guess file format: no file extension
Is there something glaringly obvious that i (someone that isn't to familiar with using the command promt in CC) can't see.
I have the e57 loaded in the DB tree and its the only active e57 open.
Thanks in advance
Re: How to separate e57 files
Yep, don't use filenames with spaces, that's rarely a good idea ;)
In effect, in your command line, use quotes to capture the whole filename: "Chatham Station internal.e57".
Bouldster
Post by Bouldster »
Hi Daniel, I have tried that and its not working? I am guessing it may be to do with the file name then? I took the spaces out and it still didn't work?
cc error.JPG (217.9 KiB) Viewed 15525 times
You probably need to specify the complete path to the file: e.g. "C:/XXX/YYY/ZZZ/Chathamint.e57"
Bouldster
Post by Bouldster »
Ah, yep that’s got it.
Thanks Daniel
