Can't export to las
Posted: Wed Mar 13, 2019 6:02 am
by muzo583
Dear Daniel,
I can not export las file which I uploaded correctly. when I tried to export same file as las, error prompts
"PDAL exception writers.las:Unable to convert scaled value(4064716612) to int32 for dimension Y when writing file/path/file.las"
Cheers.
Windows 64 bit
CC latest
Re: Can't export to las
Posted: Fri Mar 15, 2019 2:41 pm
Can you send me the file? (admin[at]cloudcompare.org)
Posted: Fri Mar 15, 2019 3:43 pm
by muzo583
Thank you for responding but it is very strange. Now the file works normally. Is there a possibility like that? if I encounter this error again I can send the file.
Cheers.
Posted: Sun Mar 17, 2019 12:33 pm
That's weird indeed. Don't hesitate to send the file whenever you have an issue ;)
Posted: Sat Jun 01, 2019 3:16 pm
by lfsantosgeo
Hello!
I'm having the same issue now. Can't export to LAS or LAZ format.
CC version 2.10.2 Zephyrus on Windows 10 Pro 64-bit.
I got my file processed with LAStools v. 190507 (latest from rapidlasso website) using lastile, lasduplicate, las2las, lasmerge. But also the original file doesn't save.
The exception is: PDAL exception 'writers.las: Invalid value '0' for argument 'minor_version'.'
Posted: Sat Jun 01, 2019 5:08 pm
by lfsantosgeo
lfsantosgeo wrote: Sat Jun 01, 2019 3:16 pm
Hello!
CC version 2.11 alpha (Anoia) was able to export/save into LAS or LAZ formats the mentioned clouds.
Posted: Sun Jun 02, 2019 6:54 am
Yes in release mode it works. But for.people compiling in debug mode (at least on Windows) it always triggers this exception.
Posted: Tue Apr 20, 2021 5:18 pm
by greg
hi there,
I'm using the cloudcompare version v2.11.3 and I run into a similar problem, as I have tried to save a .las file:
PDAL exeption: No type found for undefined dimension.
Has somebody run into a similar problem?
Many thanks for your help.
All the best,
Gregor
Posted: Tue Apr 20, 2021 9:38 pm
by WargodHernandez
greg wrote: Tue Apr 20, 2021 5:18 pm
hi there,
All the best,
Gregor
Can you create a bug report here at the
CloudCompare Github
Please make sure to include what the template requests.
