Animation plugin aspect ratio / image size
gavfoster
Post by gavfoster »
I'm fairly sure the answer is no but is it possible to set the image / movie size and aspect ratio when rendering stills or animations using the CloudComapre plugin.
Thanks for any help on this one.
Gav
Re: Animation plugin aspect ratio / image size
Actually you just need to resize the 3D view before rendering the animation (you can see the window size that appear in the bottom of the 3D view when you do this).
gavfoster
Post by gavfoster »
Not sure why i didn't think of that ! Sometimes the solution is just too obvious.
Thanks for the feedback.
Gav
