Export contour lines as shp with values
Posted: Fri Aug 30, 2019 2:55 pm
by foxx1
I created contour lines of a point cloud and exported them as a shapefile to open it in ArcMap. It opens successfully but I can't find any height values in the attribute table of the exported shape. My question is: How can export contour lines as .shp with height values included?
Thank you in advance
foxx1
Re: Export contour lines as shp with values
Posted: Fri Aug 30, 2019 10:13 pm
Which tool did you use to extract the contour?
Posted: Mon Sep 02, 2019 7:08 am
by foxx1
Hello Daniel,
I used File --> Save and then choosed .shp
Posted: Mon Sep 02, 2019 6:12 pm
No, I meant to "compute/create" the contour polyline?
Posted: Thu Sep 05, 2019 7:20 am
by foxx1
Hello Daniel,
Tools --> Projection --> Rasterize --> Contour Plot --> Generate --> Export --> Close
Afterwards I save the contour plot as a .shp file.
Greetings
foxx1
Posted: Thu Sep 05, 2019 9:14 pm
Have you selected the right options?
Posted: Fri Sep 06, 2019 8:55 am
by foxx1
Thank you! :-) I forgot to select the option you mentioned in the screenshot...
