Scalar Fields
CaseyM
Scalar Fields
Post by CaseyM »
I have three separate Cloud2Mesh comparisons within CloudCompare. I'm attempting to display the three comparisons within the same image. Is there a way to either have the three images displayed next to each other with a consistent scalar field, or to adjust the field on each comparison individually so that a consistent field can be used across the three comparisons?
The range of distances is between 0 and 14 across the three comparisons however the highest value of each set differs.
Do you have any suggestions?
Cheers,
Casey
Re: Scalar Fields
If you want consistent colors over your 3 clouds, you should create a custom 'absolute' color scale.
See https://www.cloudcompare.org/doc/wiki/i ... es_Manager.
Then either you render the screen 3 times (and compose the image), or you can simply translate (with 'Edit > Apply Tranformation') 2 clouds of the same quantity on the left and on the right of the 3rd one...
