Adjust point cloud with polylines and merge into one file
layg07
Post by layg07 »
Hi!
I would like to know if it is possible in Cloud Compare adjust the point cloud. I need to draw precisely sidewalk and road, at the same time those should be plain ( no contour lines inside road or sidewalk).
In attachment is an example of how it was done in Civil, but I would like to know if it is possible to do it somehow in Cloud Compare? Maybe with polylines?
Later I want to export one file as .csv or .txt and import it to Revit, so Revit makes the correct toposurface with plain roads and sidewalks.
Thanks!
Re: Adjust point cloud with polylines and merge into one file
Sorry, what do you mean by 'adjust (the) point cloud' exactly?
