Obtaining the eigenvalues of the point cloud
juacarri
Post by juacarri »
Hi! I'm trying to calculate some of the variables of the "Compute geometric features" tool using python, but I'm getting slightly different values for the eigenvalues compared with CC with a distance neighbourhood of 10cm. I attached the very simple point cloud I'm testing.
This is being my procedure:
import numpy as np
A = np.array([[728049.836,  4395284.986,  201.337],
[728049.849,  4395284.988  ,201.338],
[728049.852 , 4395284.982 , 201.337],
[728049.840  ,4395284.977,  201.335]])
covariance_matrix=np.cov(A.T)
[[5.62499999e-05 5.58333418e-06 4.41666670e-06]
[5.58333418e-06 2.35833325e-05 5.74999993e-06]
[4.41666670e-06 5.74999993e-06 1.58333333e-06]]
eigenvalues = np.linalg.eig(covariance_matrix)
[5.76848763e-05 2.37209627e-05 1.08268506e-08]
Using CloudCompare I'm finding the following values:
[0.000043 0.000018 0.000000]
Someone has any idea where is my error?
Test.zip
(326 Bytes) Downloaded 990 times
Re: Obtaining the eigenvalues of the point cloud
Maybe it's due to the large coordinates? Are you applying the Global Shift when you load the cloud in CloudCompare?
And is numpy properly handling these big numbers? (I would say yes by default, but who knows?)
juacarri
Post by juacarri »
Hi Daniel! Yes, I applied the global shift in CC. I tried again the same code but using the shifted coordinates and the result is the same. Could be possible to obtain an intermediate result from CC as the covariance matrix?
You would have to hack the code to do that (and log the information you are looking for around here: https://github.com/CloudCompare/CCCoreL ... d.cpp#L222)
