Is there a way to get Cross Section Curves from Mesh?
DaanS
Post by DaanS »
Hi everyone,
I created a Mesh from a Point Cloud in CloudCompare. From this Mesh would I like to create Cross Sections the Same Way as you can from a Point Cloud.
In the image below I overlaid the created Mesh and the created Cross Sections (based upon the Point Cloud) as reference.
Is there a way in CloudCompare to create these Cross Sections straight from the Mesh?
Kind regards,
Daan
Re: Is there a way to get Cross Section Curves from Mesh?
Ah no, sadly CloudCompare doesn't extract contours/envelopes from meshes! (since it's a little bit focused on clouds)
