no Qt platform plugin could be initialized
Posted: Mon Nov 29, 2021 3:36 pm
by AntoninoC
I downloaded the CloudCompare code using git and after changing some lines of code in the ccCommandLine file i created a new CloudCompare.exe file. I would like to use this new application on different machine, so i created an installer using VisualStudio2019.
After this, I installed the new executable on a new pc and the error I get is the following:
"This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: windows."
Am I missing any libraries?
Could you help me?
Thanks!
Best regards
Re: no Qt platform plugin could be initialized
Posted: Mon Nov 29, 2021 8:23 pm
Ah, it's probably because you don't compile CC with the same compiler and dependencies as the official version.
Normally, you are not supposed to do it this way... You should create a plugin with its own command line option (that's now supported) and then only distribute the plugin (changing the executable is dangerous and you may infringe the GPL license depending on whether your modifications are public or not).
Another option is of course to share your changes with everyone and integrate it in the main branch / project.
Posted: Tue Apr 16, 2024 7:10 am
by dlauener
This is still the case with 2.13.1 version (CloudCompare_v2.13.1_setup_x64.exe) from March 2024, source:
https://www.cloudcompare.org/release
Obviously, I did not compile anything, just downloaded the fresh new installer of this wonderful tool.
BTW: congrats for the job achieved: amazing !
Kind regards
Dany
Posted: Thu Apr 18, 2024 12:11 pm
That's weird... Have you tried a clean uninstall/reinstall process?
Posted: Wed Apr 24, 2024 7:28 am
by dlauener
Yes Daniel,
I did the following:
- run command line in admin mode:
sfc/scannow
errors corrected...
- upgrade graphic driver ... (AMD Radeon is hidden there, but everything was working fine previously!)
- uninstall / install fresh with and without Python & 3DFin plugins
- uninstall / install fresh with and without Faro
- uninstall / install fresh with no plugin at all
About Qt: another software using Qt 5.15.2 is running perfectly on the machine (as before).
Any idea welcome
Posted: Sat Apr 27, 2024 5:18 am
Which version of Windows are you using?
