How to Click on the point cloud in 3dviewer and select the data in the dbtree.
Posted: Mon Jan 10, 2022 9:57 am
by xiaolu
hello ,
I have a problem and want to ask,
when i load a lot of point clouds,
On linux,I click the point cloud in 3dviewer, and the corresponding point cloud will be selected in dbtree.
- DeepinScreenshot_select-area_20220110175620.png (82.48 KiB) Viewed 9316 times
But I can't on windows. What needs to be done.
thanks.
Re: How to Click on the point cloud in 3dviewer and select the data in the dbtree.
Posted: Mon Jan 10, 2022 9:03 pm
Sadly, some graphic cards driver don't properly support all OpenGL commands. And the OpenGL 'picking' command we use is kind of old and more and more deprecated... Which means that this feature simply doesn't work with some graphic cards/drivers!
Posted: Tue Jan 11, 2022 9:45 am
by xiaolu
thanks QAQ
Posted: Fri Jan 14, 2022 3:20 am
by xiaolu
Today I implemented this function in windows,
the reason is:
mouse click is difficult to point to point in 3dviewer,
if I click to point, the above function can be realized.
Is there a way to increase the sensitivity of mouse clicks?
Posted: Fri Jan 14, 2022 7:20 pm
Sorry I'm not sure to understand
