clip a mesh
Posted: Mon Mar 07, 2022 4:29 pm
by nikoue
I am sure, If I haven't seen that in my dream, that in the past I was able to use the section tool in meshes. Now this tool don't affect meshes but only point clouds.
Is there any mistake from my side, or I just remember wrong?
Thank you.
Re: clip a mesh
Posted: Mon Mar 07, 2022 4:43 pm
Are you referring to the 'Cross section' tool (then yes, it works with meshes) or the 'Segment extraction' tool? (then no, I don't believe it has ever worked with meshes?).
Re: clip a mesh
Posted: Mon Mar 07, 2022 5:05 pm
by nikoue
Yes for the cross section tool. I am sure it used to work. Now just shade the part I try to section.
Re: clip a mesh
Posted: Mon Mar 07, 2022 6:44 pm
by nikoue
take a look, please.
what I am doing wrong?
Re: clip a mesh
Posted: Tue Mar 08, 2022 9:28 pm
Ah, that's a glitch, because the sub-meshes (all the entities named 'default') are also visible and hide the segmentation.
The current workaround is to select all these sub-meshes, and deactivate them at once (shortcut 'a'). Then you'll be able to use the Cross Section tool normally.
I'll try to fix that asap.
