Cloud/cloud compare - rotation
ziga8
Post by ziga8 »
I didn't find any similar question on the forum so I decided to ask it.
I have two clouds (for example two boxes), one is data (or reference) and other on is rotated (for example; 5 deegres around X-axis). The program registrate clouds really well, but is there any kind of chance that program shows rotation of the model (I know that I rotate it fo 5°, so I need a confirmation from the program)?
I hope you understand!
Thank you!
Best regards, Žiga.
Re: Cloud/cloud compare - rotation
Apart from the resulting transformation matrix (that appears in the console) you won't get any such information. You could try to transform this matrix in the vector/angle format (if the rotation is really simple, you should get what you are looking for).
ziga8
Post by ziga8 »
Thank you for the fast answer!
I'll figure out something:)
ziga8
Post by ziga8 »
One more question:)
What's "your" definition of transformation matrix? I can't find it anywhere. Do you have any source link or something?
Thank you!
Best regards, Žiga.
Oups, I forgot to reply to your last question ;)
For the records, the 'Transformation' matrix is a 4x4 matrix with a rotation matrix included in the 3x3 upper left part and a 3D translation in the upper part of the last column. The bottom right element is always 1 for consistency.
See for instance http://www.fastgraph.com/makegames/3drotation/ (Tr).
