Best Fit Sphere Command Line
caudete69
Post by caudete69 »
I would suggest adding something like -BEST_FIT_SPHERE to the command line options. I'm currently using cloudcompare in the command line to automatize measures. The BEST_FIT_PLANE is working perfectly and is easy to put into a bash file. I need the same but for SPHERE.
Thank you in advance. Keep the great work!!!
Re: Best Fit Sphere Command Line
What output would you expect? The fitted sphere as a mesh (in memory) or something else?
caudete69
Post by caudete69 »
Sorry for the delay in answering.
I expect something similar as in BEST_FIT_PLANE, the mesh in a file if possible. Another possibility could be the radio and center of the sphere as answer.
Thank you!!!
I added it to the (way too long) TODO list.
